Results 1 to 20 of 20
Thread: underside panel
    May 2015
    Abbeville Al
    Default underside panel
    The plastic panel on my wife's 2013 STS came loose and it rubbed on the road and tore it up pretty bad. I have what is left tie wrapped up. I know a lot of people take them off when they change their oil and put them on the shelf. My wife wants hers fixed. I tried to talk her into just removing it but no luck. She likes things the way they were made. If someone had one that they would like to get rid of it sure would get me some needed ataboys. Thanks in advance.
    Default Little checking..
    I would just order a new one from cheapcycleparts.com and replace it. Few, if any, methods of repairs on plastics don't work well. Seems every time a glue comes out to fix plastics they change the compounds so they won't work on the new stuff...
    Jul 2010
    Las Vegas, NV
    Default Picture
    Take a picture of what you need. I have 6 belly pans on the shelf; I don't remember what they came off of. I do know that they are better on the shelf. If I have a match, it's yours. Joe
    Joe Meyer
    Jul 2011
    Mitchell, Ontario, Canada
    Here is the exploded view.
    I would guess you are talking about left item 61. Goofy there are 2 item 61's It's only $20 CAD new. It will be even less in USD.
    61 705005413 LH Deflector Pannel. ST, ST-S, $19.84 CAD
    61 705005414 RH Deflector Pannel $19.46 CAD
    May 2015
    Abbeville Al
    cptjam
    It is #61 in the diagram above. I will try to get a better pic.
    Jul 2011
    Quote Originally Posted by jcasey View Post
    cptjam
    61 left or 61 right?
    May 2015
    Abbeville Al
    Can't get it to attach. But if you go to cheapcycleparts to this link you can expand it. Let me know and thanks!
    http://www.cheapcycleparts.com/oempa...nd-accessories
    May 2015
    Abbeville Al
    61 right
    May 2015
    Abbeville Al
    #95 on the procaliber site.
    May 2015
    Abbeville Al
    Quote Originally Posted by cptjam View Post
    61 right on cheapcycleparts and 95 on procaliber Thanks
    May 2015
    Abbeville Al
    For some reason it won't let me quote. Sorry for all the post. To be clear it is the 61 on the right looking at the diagram and on the left when sitting on the Spyder. It is the larger 61 Thanks
    Active Member Richardv's Avatar
    Oct 2014
    Montreal north shore, QC
    Default Oil change one is left...
    .... just replaced it on my son in law spyder.... always talk as when sitting on the bike.
    Richard
    * 2012 RS SE5 (hers)
    * 2013 ST SM5 (mine)
    Daughter RSS SE5 2014
    Son in law RSS SM5 2013
    P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
    2 sets of Kumho 175/55R15 front tires
    1 set of Hankook V4
    1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
    Dec 2012
    Murphy, NC
    Default Panel
    ​I think I have one left over from my ST-S. I'll check after work and if I still have it, I'll send it to you for a small shipping charge.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Jul 2011
    This one.
    May 2015
    Abbeville Al
    Quote Originally Posted by JKMSPYDER View Post
    May 2015
    Abbeville Al
    Billybovine
    For some reason it will not let me quote. Don't care how much text I put in it says I have to have at least two words! But yes the panel on the left sitting on Spyder
    If you take those underbelly panels off your Spyder will run cooler. Engine compartment temps are greatly reduced. Less heat on the fuel tank will also lower the fuel temperature and create less vapors. And you'll bet less heat coming up around the seat. There really isn't any down side to leaving them off. Also makes routine maintenance much easier.
    May 2015
    Abbeville Al
    She won't buy it! Wants it the way it was designed.
    Jul 2010
    Las Vegas, NV
    Default Nope
    I don't have that one! Sorry. Cheap, buy her a new one. Spoil her!
    Joe Meyer
    Too bad. She's missing out on an improved ride. But, to each their own.
