Results 1 to 11 of 11
    May 2016
    Texas
    Default How does it work ?
    How does it work
    May 2016
    Central Indiana
    I think you have to have the factory CB system. Someone else will jump in and correct me if I'm not right. The PTT means ( Push To Talk )
    Active Member scarecrow's Avatar
    largo, florida
    It attaches to the flux capacitor. If you push the "Push to Transport" button exactly at 60 mph you my make that restaurant reservation on time.
    2014 RTS , Cognac
    "Push to Talk"?
    Mine doesn't work correctly : I never push it, yet my Missus talks ALL of the time!
    Jun 2014
    People's Republic of NY
    Quote Originally Posted by 2013REDRTS View Post
    No think needed. The PTT does nothing without the factory CB installed. So far none of us has been able to come up with any sort of addon that would make use of it.
    Dec 2015
    Galax VA
    Quote Originally Posted by manman007 View Post
    How does it work
    How does what work? Push the R button and you go backwards, push the PTT button and you get to talk to someone that could care less. LMAO
    May 2016
    Texas
    Quote Originally Posted by Sam Mac View Post
    Really ????
    Mar 2016
    Akron,Ohio
    I may put a mobile ham radio in my bike this next winter!! I would think I could convert the CB harness to a ham radio. Big question is antenna. I could probably mount it in the CB antenna spot. Could be a fun project!!
    May 2015
    Oregon, USA
    Quote Originally Posted by RussRT View Post
    If you figure this out, let everyone know! It's not just a harness, it is integrated into the CB radio electronics, so you can change channels, etc.. from the handlebar controls.
    The PTT switch is connected to the CAN BUS, and is pretty much useless outside of the BRP CB, from what I can tell.
    -Fratz
    Quote Originally Posted by fratzba View Post
    I think it can be done, but you have to figure out how the communication connection between the CB and audio unit works. The PTT , the audio unit, and the cluster are all connected to the CanBus. The CB is connected to the audio unit only. When you push PTT the left handlebar module sends a command via CanBus to the audio unit which then sends a transmit signal to the CB. I think it may just be a steady high signal. The reason I think this is because the passenger PTT, which is a button on the headset cord, closes a separate circuit to the CB.
    A complication you have to take into account is the fact the headsets connect into the CB unit. All the audio from the audio unit goes to the headset via the CB. The CB is also the intercom unit.
