Originally Posted by Y-Ryder
Did the dealer have to keep the adjustable wings for you to get credit?
Originally Posted by Magdave
Yes. Why would they give you money for something you bought and kept that could be used on other models? You can't sell them for full price used but you can get MSRP credit for them.
Not sure about that. The install instructions direct the dealer to discard the wings. There's nothing in the recall instructions requiring the dealer to keep adjustable wings in order for us to get credit. The credit comes from BRP, not the dealer. I haven't gotten my credit yet. The dealer missed that part in the instructions. I had them discard them into my trunk so we'll see what the end result is. I figure I just as well keep them rather than sell them as I hope to buy a '14 or '15 RT this fall. They'll fit on it.
Gotta send them back.
My service manager originally told me I could have the wind deflectors back. But after he talked to BRP , he said he had to send them back. He said the reason was that BRP reimburses 100% for them even without the receipt. For that reason BRP does not want them resold – either by the customer or the dealer. If that's true, and I have no reason to believe that it isn't, I think it's a bit petty of BRP. Really, what are they going to do with all those used wind deflectors?
Other reimbursements are not reimbursed at 100%. in addition to the credit for the wind deflector's, I only got $250 credit against about $1500 in labor that I spent to previously remedy heat issues. And I had receipts for that. (Of course, the cat bypass was completely out of the question. )
I had my recall done last Summer and am well pleased with the look and function of the air scoop. My one question is : How is it removed? Just in case the need arises.
The scoop comes off with the panel. The panel is removed in the normal fashion, EXCEPT there is a fastener under a small plastic cover on the inside edge of the scoop.
"a fastener under a small plastic cover"
Any chance anyone has a picture of this "fastener under a small plastic cover on the inside edge of the scoop"?
Pitbull added the '13 vents to my '12 RT back in October and I recently took them off the side panels for painting to match the Viper red body. All I had to contend with was (5) screws holding the vent assembly onto the side panel and then remove (4) more screws to disassemble the four parts of the vent assembly. All (9) of those screws were standard self tapping screws with a T20 Torx head.
What am I missing here? Did BRP produce more than one version of these vents? Inquiring minds want to know.
Mike in KY
Mike in KY
Gray is referring to a machine screw that has to be removed in order to get the panel off. It's in the same place the lower mounting screw for the air deflector used to be. Obviously, if you took the panels off to have the scoops painted, you had to have removed that screw!
Yes sir, guess I didn't read his post carefully enough.
Mike in KY
