Results 1 to 18 of 18
    May 2011
    Texas
    Default Need some help - on road right now and stranded
    Hi everyone,
    riding today day and need some assistance. I was almost run off the road by an idiot so I pulled over to stop and catch my breathe. I turn off my 2011 RS and used the kill switch. I then turned the me to ignition after a few minutes and hit the mode button and power button and everything shut off. Now when I turn the key to ignition nothing comes on at all. i tried to find anything online about it being an electrical thing but can't figure it out. Is this a limp home type thing that anyone knows how to fix? I literally get nothing as thought there's no battery. Yet the battery is not bad or old and everything was fine on its last check up about a month ago
    thanks in advance.
    Jan 2015
    southern WI
    Pull the key for a minute or so, double check the kill switch, gear position, etc....then try again?
    2016 RTS , Pearl White
    Active Member DunaJ's Avatar
    Feb 2013
    Rowlett, Tx
    What is the age of the battery? The same thing happened to me: I took it off the tender, left the house went in an 45min ride, stopped to get gas, and nothing. Yep it was a bad battery even though the charger said it was good before leaving the house.
    May 2011
    Texas
    Quote Originally Posted by MZEMS2 View Post
    Took the key out for five minutes actually. It is a SE5 transmission so I can't check the gears without a display unfortunately. I know it was in neutral when it died out though.
    Jan 2015
    Florence, Oregon
    Default Dead After Sudden Stop
    Quote Originally Posted by Toxziq View Post
    Hi everyone,
    thanks in advance.
    Check the battery connections, it is possible that you have a loose / corroded terminal and the sudden stop may have jarred the connections so now you have no power! Hopefully you have the Tool Kit on the Trike, good luck.
    MercerLake
    May 2011
    Texas
    Quote Originally Posted by MercerLake View Post
    MercerLake
    I do but I'm not familiar with how or where to look for that. Is there a link you might have I can check it out?
    May 2011
    Texas
    Ok it's weirder. If I turn my hazards on with the key out of the ignition they work. The moment I put the key in and turn to ignition they turn off
    Very Active Member dlby's Avatar
    Nov 2014
    Indiana
    I think your kit is under seat
    Battery may b as well
    Loose battery connections are always very weird
    I HAVE a 14 rt so dont kno much about your trike
    I can look it up
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Sep 2011
    Allen, TX
    Ok, try this. Remove key and walk away from spyder (10 - 15 feet) wait approximately 10 minutes. As mentioned before you may need to check battery connections. Goog luck.
    Mar 2013
    Oz
    Don't know if you're still stranded but, even tho in neutral, put foot on brake? catches me out sometimes.
    May 2011
    Texas
    Unfortunately no luck with anything so I called a tower and am on the way to the shop. Thanks for everyone's replies though. I haven't been able to use this forum much the last few years but it's good to know we have each other's backs. Thanks guys, start safe!
    May 2011
    Texas
    Quote Originally Posted by loisk View Post
    Tried that. Unfortunately no luck.
    Bossier LoUiSiAna
    Let us know how it turns out does sound odd,especially the hazard lights thing. Share what you find maybe we can help others.
    Feb 2013
    Rowlett, Tx
    Any Updates on what your issue was?
    Oct 2014
    cohoes ny
    yes please let us know how you make out. good luck!!!
    May 2011
    Texas
    well, took a while for the shop to look at it but it appears my battery died. So they are replacing it and it's off to the races again. Alls well that ends well as they say.
    Well; at least it's a simple fix!
    Glad to hear that you're back up, and "on three"!
    Nov 2014
    Indiana
    Yep
    As I chimed in b4 bad batteries give a lot of weird results
    Glad your Ok!
