I have kind of lost track of which thing was said and when but they did say either when I posted back on June six or maybe early July that they were waiting for "master cylinders". I hope that they will be available on or before Oct 4 for those that need a hand brake but............on the off or not so off chance that they are not you might start looking at alternatives. I was lucky enough to have a friend with what is essentially a machine shop so Jim was great getting my brake done. I was going to go to an adaptive shop that does van conversions and hand controls for the disabled to get the job done so if there is a business in your area that does this type of work you might give them a call.
I am so used to my set up now I don't have any plans at this point to buy the ISCI hand brake.
ISCI just called me and they are scheduling the F3 brake kits to start shipping on Tues or Wed of next week.
Yes I did order a kit and they are sending me the mounting instructions by e-mail so I will be able to understand how the kit attaches and works.
handbake
Mike,
Thanks for the update, did they give you a price?
ric
Originally Posted by rjs
Mike,
ric
Regular price was quoted $1,595.00. He did offer a discount but not sure exactly the amount. I think it will be about 10%
ISCI Handbrake
Mike,my order is in and i have the instructions for the install it looks like they are waiting for the master cylinder from Italy the instructions are for the footpeg not the floorboards do you
see that causing any problems? Justin also said that the install should only take about an hour
Im sure my dealer will take longer than that.Justin also said that the brake lever has some ajustment in it thats a good thing. the lever I had on mt ST limited was quite a reach.
Ric
Ric
No I don't see the floor boards being a problem. The mount for the slave cylinder mounts the same and the clevis attaches to the front of the stock brake rod so shouldnt interfere from what I could see from the instructions that they e-mailed me. Check the bottom of page 5, it shows that all of the hardware is installed on the inside. You can see where the peg bolts back on and that is where the floorboard bolts as well.
I will take my time so it probably will take me longer, but it looks easier than when I did my RS. I like the speed bleeders that they are using which sould make things easier as well. The RS was harder because everything was underneath and I did have quite a time getting the brakes bled.
Reason: Additional information
SpyderLovers Sponsor
YOUR WAITING IS OVER
F# hand brake is now available from MotorcycleDave.com
Hand Brake
Motorcycle Dave thanks for the update it has been a long wait.what master cylinder did you put in the kit?
