Results 1 to 7 of 7
Thread: Givi top box
    Very Active Member Vader's Avatar
    Hudson Valley
    Default Givi top box
    I decided to do a little searching and found a Givi top box on Craigslist. $85.
    I had removed the factory backrest already being I highly doubted I would ever have a passenger. I removed the backrest from the base for storage. I replaced it with the sport rack plate.
    I decided to mount the Givi to the backrest base so I can switch with just the pull of the release under the seat. I used 4 Deltec cables to attach the Givi mounting plate to the backrest base plate. These cable ties have a breaking strength of 250lbs.
    I think it turned out pretty well.
    IT IS, WHAT IT IS...
    Jul 2015
    Australia
    N. Va
    Which top case do you have on now? It looks like the size I am going for; a big improvement over oem offering.
    Jerry
    Hudson Valley
    Quote Originally Posted by spacetiger View Post
    Jerry
    I believe the guy I bought it from said it was a Givi E460
    Active Member Nokesy's Avatar
    Mar 2017
    Newmarket
    Quote Originally Posted by Vader View Post
    It is the same as a besteem 924 box that I have
    Done all of Canada except NWT and parts of Australia, New Zealand and areas of Europe
    Active Member WisconsinDavid's Avatar
    Sep 2018
    Beaver Dam WI
    Default Looks Great
    That looks really great. I'll start searching for a top box to put on. The mounting system you used looks simple and strong. Thanks for the idea! Ebay, here I come.
    Hudson Valley
    Default Thanks!
    Quote Originally Posted by WisconsinDavid View Post
    I like the simplicity of the set up. I can remove the case and add the sport rack top plate without tools in a less than 30 seconds. There is also a built in pad on the case for the passenger.
    Good luck with your search, and keep looking on SL for more ideas and other cases that people have used.
