Results 1 to 25 of 27
    Active Member danotech's Avatar
    KC
    Default 2013 RT Scoops on 2014 RT
    Has anybody installed the scoops on a '14 RT? I saw several on '13s this morning and love the look! I checked on the parts and they are available. If you have done it were there any issues?
    Sent from my LG-V496 using Tapatalk
    Default Don't know..!!
    Heard they will not be available till all the recall work is done. Had someone trying to get the scoops for a 2010 but could not...
    KC
    I know where I can get them but am a curious if they will fit?
    May 2009
    Connecticut
    Ordered and received in 3 Days for the 2012 ($70 Plus $50 to Cut the panels) and I installed! Dropped panels Off and Picked up then took 2 Hours (Slow) to install at home!
    2014 May be different size panels? Probably Do Not need it with the ACE1330?
    Sea Doo GTI-SE 90 Jet Ski!!
    Mar 2008
    Hesston, PA
    Default 13/14 Air Scoops
    I have a set to do my 14 RTS but I'm too busy to start that project until I get back from my Hatfield & McCoy trip the first week in August...BUT I KNOW SOMEONE ELSE THAT WILL SOON BE DOING THIS TO THEIR 2014 BEFORE ME...STAND BY...larryd
    Oct 2013
    Gold Coast QLD Australia
    Find it amazing just how many people want their RT's to look just like my 2013 RT. 😉
    Regards
    Kenn
    Nov 2012
    North Las Vegas, NV
    I'll see my dealer this week and see if I can get the scoops for my 2012 RT.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jun 2010
    Las Vegas
    Quote Originally Posted by KennW View Post
    Regards
    Kenn
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    I saw these scoops installed on a 13 and I too am interested on installing on my 14.
    They look awesome.
    2022 F3 Limited , Monolith Black / Dark
    Very Active Member SpydermanCT's Avatar
    Nov 2010
    Connecticut
    I can not tell you if they will work on your 2014 but for clarification I had them installed this week on my 2010 RTS at Gargano GSS Powersports in East Haven, CT at no cost. The owner Bob Gargano said that he was able to get reimbursed for the work by submitting it as a good will claim. I will also add that there is a substantial ​reduction in heat after the installation.
    SpydermanCT
    2010 RT-S SE5 Timeless Black PE # 794 ~ RT-622 Trailer ~ Can-Am Garmin 665 GPS ~ Elka Front Shocks ~ ESI Brightsides with Rips Kit ~ ESI RT Fender Tips Kit ~ Rear Brightsides ~ HMT Brake Light ~ Tricplate rear running / Brake LED's ~ ESI Mud Flap Lights ~ LED Day Runners ~ Right Side Inlet Covers ~ Street Magic Scuff Guards ~ IPS Key Cover ~ KewlMetal Kewlocks ~ Spyderpops Radiator Block Off Plate and Catalytic Converter Shield Set ~ Carbon Fiber Kit ~ Corbin Seat
    Danbury Connecticut
    Quote Originally Posted by SpydermanCT View Post
    Nicely done ! I'd love to see them.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Mar 2015
    NE Kansas
    I don't completely understand this thread. What would be the point in installing the scoops designed to remedy the 13 heat issues on a 14? Seems to me that it would be purely aesthetics. What am I missing?
    Since when are aesthetics NOT important?
    While there may not be the need for them on the 1330 bikes; they do look pretty awesome!
    (I saw my first "scooped-up" 2013 yesterday...)
    Mar 2015
    NE Kansas
    With the amount of money that I spend on must-have farkles (just ask my wife, lol!), I would never question someone wanting the scoops for the looks. Just didn't know if there was some other reason, since my 14 RT has zero heat issues.
    Nope; we don't need them on the 1330s...
    I like the look of them on the 2013s.
    It's another visual cue, to distance them from the prior bikes...
    May 2014
    Benson, NY
    After all the doubters over the 2013 fix BRP has got to be grinning ear to ear now.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    May 2009
    Connecticut
    Your Dealer CAN get the Kit for $70 (If out of warranty like me) and you bring in the Panels to get cut-If your dealer will do this (?) and then you install them. The instructions are part of the recall instructions posted in the other thread about this.
    I was out in 85 degrees and never went above 4 Bars when at a constant speed! Its a Must to also take of the Acoustic panels under the Tupperware and If you have a 2010-2012 the 2 underneath panels are very easy to take off if you jack it up and look for 2-3 10mm Small bolts that hold on the lower panels-2 are attached to the middle frame.
    With ALL 3 done the air enters the scoops- Flows over and around the cylinder heads and gas tank and then a Lot of it escapes underneath through the panels removed underneath.
    PS: Someone PM,d me about this but its better to ask the "Whole" group.
    It turns out the 2013s WILL end up being the best of the 998 bikes!
    Active Member mustangbob's Avatar
    Jun 2013
    jackson, michigan, USA
    Default Scoops
    I have a 12 ' RTS and the scoops are being installed Aug 4th by the dealer at no cost to me. BRP good will warranty claim. So if your dealer tells you BRP is not covering older RT"s they are not going to bat for you.
    2012 RTS SE5, GT stripes, belt guard, hmt brake light, lower vent heat deflector, driver foot boards, Corbin seat, RH vent covers
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Quote Originally Posted by Sarge707 View Post
    Make sure you keep your receipts. If BRP ever issues a Warranty Bulletin to install the scoops on the 2012 RT's, you should be reimbursed. Since they work so well on the 2013's, that may not be as far fetched as it sounds.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Oct 2013
    Pottstown, PA
    Quote Originally Posted by Bensonoid View Post
    I'm sure that Steve is, at least. But he'll never say that.
    Rob
    2013 RT Limited
    Oct 2013
    Pottstown, PA
    I always knew that, somewhere in the back of my mind. ...but somehow, I managed to keep my mouth shut when everyone was discouraging potential buyers away from the 2013 RT, even though they could be had for huge discounts.
    Rob
    2013 RT Limited
    Jan 2013
    victoria,bc
    Default 2012 rt se5 ltd
    Quote Originally Posted by robmorg View Post
    I just had the Scoops installed on my 2012 rt se5 ltd and there is a HUGH reduction in the heat around the upper leg panels and center glove box and seat.I feel no heat in those areas and hardly a warm right foot.
    I would like to thank Ladysmith Motorsports here on Vancouver Island for going to bat for me.
    May 2009
    Connecticut
    Thanks! Mine was out of warranty But I mentioned the "Good Will" phrase - I will keep the CC Receipt for sure!!!
    $125 was a worthwhile Donation BUT I will deduct it off my F3 Offer in Mid-October?
    Jan 2013
    victoria,bc
    I didn't have to pay for the scoops or labor as BRP covered it.
