Results 1 to 9 of 9
    Pensacola FL
    Default Plug for Garmin Zumo
    Is there a plug in the wiring harness to plug in the Zumo power cord, I have the power cord from a 2012 RTL
    Feb 2012
    Spring City,Utah
    It appears from your profile you have a 2012 RTL. If you have the Zumo that came with that machine then you do not need a power cord,all you need to do is put it in the mounting cradle in the center of th handlebars. If you have a different Zumo,then no there isn't a place to plug it in you will have to make one.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Pensacola FL
    I have the 12 RTL, put Tri-axis handlebars on for the wife. The mount no longer fits, there is a new one. I have ordered the part to mount the Zumo mount to the handlebars of my F3S.
    The question is, is there a connection in the wiring harness of the F3 that I can plug the plug that is on the Zumo Mount into. On the RTL, you just plug it in. Has one of those waterproof compression connectors on the end of it.
    Pensacola FL
    Unhappy
    BUMP
    Feb 2012
    Spring City,Utah
    Thank you for the further information. I am sorry I don't know anything about F3. Hoprfully someone will jump in here soon to help you out.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    May 2015
    PA
    Lightbulb
    I have an F3 but I use a switched power supply for my Zumo 590 that I installed in the frunk. I did, however, keep a link to this thread which may help you:
    http://www.spyderlovers.com/forums/s...Assessory-wire
    In that thread is a link to Wiredux and their 2 pin power bridge adapter that they also recommend but that link doesn't appear to be working for me today. Spyderpops can provide that Wiredux part to you and here's the link to it on their site: http://spyderpops.com/brands/WIREDUX.html
    Hopefully this info should get you started.
    2015 F3S , Black
    Aug 2012
    Jacksonville, NC
    When I got the 590 and handlebar mount for the F3 it came with everything needed, and it has the connector on the end. If you need a connector, PM me.
    Pensacola FL
    Quote Originally Posted by Wiredux View Post
    Mine mount has the connector on it, I am wondering if there is a place on the wiring harness to plug that connector into?
    Aug 2012
    Jacksonville, NC
    Quote Originally Posted by Moosemanj View Post
    On the F3, the GPS power is on right side, under the small rear panel. You will have to remove the seats to be able to remove the panel. Make sure you check the polarity of the connector before you just plug in your GPS.
