Page 1 of 2 12 LastLast
Results 1 to 25 of 30
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    Default Didn't last a week!
    Haven't even had it for a week and already started the mods! First and most important mod was to add an aux power switch and my home-made garage door opener. This switch matches nicely and provides OFF - ON - Momentary functionality. The ON position powers a supplemental fuse panel, and the Momentary operates the garage door opener. The integrated light is slightly brighter than the other switches, but a dab of paint on the bulb will fix that. I've added the power cord for my heated clothing, (which doubles as a connector for trickle charging the battery), my front and rear digital video recorder, and the Can Am Bluetooth Dongle. The only thing left for now is to add the hookups for my portable Sirius satellite radio. After that, who knows.
    2020 RT Limited , Marsala Red
    Very Active Member garb55's Avatar
    Coolidge Arizona
    welcome
    nice job
    Now 2014 RT Limited Cognac
    Was 2008 GS SM5
    Don Garbarino
    Cup Holder
    GPS locking holder
    Mud flap
    Modified KNOTT grill
    Phone holder and charger
    Trailer hitch
    Dual air horn
    Auxiliary fuse box with relays
    Heated clothing controller
    volt/oil pressure gauge
    Sequential signals in mirror
    Tri Axis Handle bars
    Baja Ron anti sway bar/heim links
    shorty antenna
    And many more
    Active Member nakerr's Avatar
    Dec 2013
    Fort Saskatchewan, AB Canada
    Nice job. Where did you source the switch?
    Norm
    ...Not All Who Wander Are Lost" - Bilbo Baggins
    2015 RT-S SE6 Special Series
    Default Well done...
    Welcome to the world of farkeling... you have unleashed the beast...
    ​2012 RS sm5
    washington state
    Great job
    2012 Spyder RT SE5 Brake pedal mod
    Very Active Member 2ndChildhood's Avatar
    Sep 2012
    Flushing , Michigan
    Where did you get the momentary switch?
    ToM
    Simplify
    Life is good
    Life is Great
    ToM
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    I'm glad to see someone else in the neighborhood likes to tinker.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Feb 2016
    Quote Originally Posted by nakerr View Post
    The switch is a Carling Contura model VMDA-2 and the actuator (cap) is model number VV C2-D. These folks have a $25 minimum order so to get there I also bought the VV C2-C actuator which doesn't have the ACC logo. If you intend on working with these switches at all, you should buy the actuator removal tool also. It is a model #VRT-CAR-REMOVALTOOL. I already had the tool from doing work on my boat. If you ever try to remove the actuator caps without using this tool, you will probably break the retaining clips and not be able to reuse the cap. You can find these parts at lots of places, but I've dealt with this vendor before and never had a problem.
    http://www.searay-parts.com/Carling-...h-p/vmda-2.htm
    http://www.searay-parts.com/Carling-...0accessory.htm
    http://www.searay-parts.com/Carling-...emovaltool.htm
    Feb 2016
    Quote Originally Posted by Grandpot View Post
    If you only knew!!
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    Default thanks
    I was just going to do a search for a switch like this
    2022 F3 Limited , Monolith Black / Dark
    Feb 2016
    Quote Originally Posted by DriftersWay View Post
    If you want a switch that has different functions than I used, there are many options. There's a great tutorial here:
    http://www.thehulltruth.com/new-wire...plained.html#b
    that explains how to "read" Carling's part numbers. You actually decide what you want the switch to do and then work backwards to get a part number. Then pick the actuator cap that you want. The list of available switch circuit diagrams can be found here:
    http://www.carlingtech.com/rocker-sw...-v-series-iv-v
    Scroll down to the "Resources" area and you'll find .pdf files of all the circuit diagrams and actuator caps.
    The switch I used is the "M" circuit. The "M" is then the second digit in the part number. This is the OFF-ON-(ON) circuit. When the ON is in parenthesis, that means it is momentary like a horn button.
    Jun 2013
    Uniontown, Pa
    Default Thanks again
    Great info now may I ask what kind of camera system you are using
    Quote Originally Posted by Jetfixer View Post
    Thanks for this information!
    Welcome to the "Wild World of Farkeling your Spyder"!
    Just for the record: this disease is incurable!
    Feb 2016
    I'm using the Innov K1 system. This system records from two 1080p hi-def cameras simultaneously, includes a GPS module, and what I feel is the best part, for a reasonable extra charge you can get 2 more cameras to mount in your car. That way you just take the recorder with you whatever you drive. I mounted the front camera just below the windshield and the rear camera using one of the license plate bolts. The gps module is installed under the seat, and the recorder module lives in the left side bag compartment.
    Jun 2013
    Uniontown, Pa
    Default Awsome
    Thanks for the info. I'll be looking into that too.
    Thanks my friend.
    Sep 2015
    La Luz NM
    Default Garage door opener
    Nice looking install. What did you use for the door opener? Just a regular one or did you do the flash to pass type? Also, would you be able to show us your wiring diagram you made?
    Feb 2016
    Quote Originally Posted by rugerbear View Post
    I have a flash to pass type that I've used on my motorcycles for years. I thought about using the Spyders' PTT switch since I cannot have the CB option due to the Bluetooth dongle option. But I believe that the PTT switch is part of the CANBUS system and not just a switch. That's why I used the OFF-ON-(ON) switch. I can turn on or off the power to my aux fuse panel (mounted under the seat) and use the momentary instead of a flash to pass switch for the garage door opener. Works great! As for the wiring diagram, are you talking about the ACC switch wiring or my whole diagram for all my add-ons?
    For those unfamiliar, you can add a garage door opener to your Spyder (or motorcycle) very easily and for less than $5. Just go to your local used auto parts yard and obtain the Homelink module from the sunvisor of any car. Just remember what year, make and model car you get it from. Then you can go to the Homelink web site and using the vehicles information, and your brand of garage door opener, get the instructions for how to program it to your opener. You can use a regular 9 volt battery to program it. The green wire is the positive and the black is the negative. I usually program the middle button on the module. Then using a nylon tie-wrap, keep the middle button pressed down permanently. Now all you need is a ground on your Spyder and a momentary switch to send the 12v positive to the module. Since the programmed button is already pushed, (mashed if you live in the south!), your door will open and close with each push of the momentary switch. You can seal the Homelink module on a plastic bag or wrap it in waterproof tape and mount it out of sight somewhere. I put mine near the battery access panel in the frunk.
    Sep 2015
    La Luz NM
    Default Switch
    I have a flash to pass somewhere that I can use. If you can share just that diagram on the acc switch, that would be great.
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    Default I'm pretty much done with farkleing
    Maybe another 20 or 30 mods ... this week.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    Feb 2016
    I can't seem to attach the wiring diagram I drew up, but for the exact switch that I used here is what I did:
    Battery positive from the wires in the frunk that would plug into the optional power outlet goes to pin 3 on the switch. (This way the power is switched off with the key if using fuse F6)
    Jumper from pin 3 to pin 6 and also to pin 8 if you want the switch internal light to work.
    Pin 7 to ground if you want the light to work. (This only provides ground for the internal light)
    Pin 2 sends the positive to my aux fuse box when the switch is in the ON position.
    Pin 5 sends the positive to my garage door opener when the momentary is pressed.
    Sep 2015
    La Luz NM
    Thanks
    Jun 2013
    Uniontown, Pa
    Default Switch ordered
    Switches are on order.
    Thanks again my friend.
    Butch
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Jetfixer,
    Very nice initial mods. Thanks so much for sharing. The information about the Carling Contura switches was especially useful,and I'm sure very much appreciated by many here.
    Welcome to the forum, and hope to see a lot of posts from you about future mods, etc.
    If you don't mind a personal question... does your username imply that you are a jet aircraft mechanic, when you are not riding your new Spyder?
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Feb 2016
    Quote Originally Posted by robmorg View Post
    Jetfixer,
    Yes. I work for the new American Airlines (formerly USAirways)
