Results 1 to 11 of 11
Thread: Bumper Install?
    Active Member View from behind's Avatar
    Aug 2015
    Taylors SC
    Default Bumper Install?
    Ordered spyderpops bumper plate today-what height ramps do I need to install them myself.....is it difficult ?
    Dec 2014
    Lee's Summit, MO
    Quote Originally Posted by View from behind View Post
    I drove mine up on a pair of car ramps. It is not difficult at all. Just follow the instructions. You will be be very happy with this product. I have 6000 on my Spyder and the bump skid has come into play at least 4 times. You will be glad you installed it. Will take about 30 to 60 minutes to install.
    Aug 2015
    Taylors SC
    Quote Originally Posted by kngfsh27 View Post
    Thanks for the info - will look into the car ramps🙋
    Idaho
    Not trying to be funny, but high enough you can slide underneath to operate a drill/driver on the bottom side. The most difficult part I encountered was drilling the back two holes into the frame. They wanted to be too close to the edge. Check out all the hole locations before you start drilling to make sure they are where the clips will hold properly.
    2014 Copper RTS
    Jul 2014
    Mint Hill, NC
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Jun 2010
    Las Vegas
    WasWinger is wight, for the 2 bolts at the back you have to be able to put some oomph behind your drill so you need to jack the Spyder up high enough to do that
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Registered Users dmfahie's Avatar
    May 2015
    Southern Maine
    I'm a big boy... installed mine a few weeks ago... bought small ramps from harbour freight. .. they do not need to be too steep
    Be safe.
    Very Active Member Orange Spyder Man's Avatar
    Sep 2014
    3rd ROCK FROM THE SUN !
    I would advise to pay close attention when drilling the 2 rear holes... they are VERY close to the radiator hoses... I used a piece of 1/2" PVC pipe just long enough to drill thru the bump skid and cross member but not allow the drill bit to touch the radiator hoses... (put the drill bit into the length of PVC)
    osm
    Those two holes are the toughest part of the installation. But if you have enough room up under the bike; you'll have no problem.
    Very Active Member JkRbbt's Avatar
    Mar 2010
    SD
    I, too, used a car ramp, but didn't have enuf room to drill the two holes in the back. I put a couple of 2x4 blocks on the ramps to give just a bit more clearance and it worked just fine. Just be sure to STOP before you drive off the ramps. There is no bumper feature on the ramps once you put the 2x4s on them!
    Aug 2015
    Taylors SC
    Talking Good info
    Thanks everyone I will pay close attention to the holes in the back -- such good info here
