Page 1 of 2 12 LastLast
Results 1 to 25 of 34
    Very Active Member Rogue Hawk's Avatar
    Apr 2015
    Chicago
    Default Has anyone ever made a Spyder hyper motorcycle?
    Like a VMax-like mod
    2019 Rally , Black
    Default WELLLLLLLLLLLLLLLLLLLLLLLLLL
    Quote Originally Posted by Rogue Hawk View Post
    ......Does putting a Turbo forced air fan, on the 1330 Ace engine count ? ? ?.........Mike
    Docdoru and AlTonk added Aerochargers...
    Apr 2015
    Chicago
    Tell me about this turbo I'm still a noob here
    2019 Rally , Black
    Dec 2008
    Syracuse, NY
    Aerocharger offered kits that fit the GS/RS Spyders...
    I guess that they were just about the equivalent of bringing, "A gun; to a knife fight", once you got them dialed-in.
    Doc ran his Spyder at Bonneville, and I think that he still holds the record for the 1000cc class.
    Very Active Member Orange Spyder Man's Avatar
    Sep 2014
    3rd ROCK FROM THE SUN !
    installing a turbo on a spyder is kinda like installing a turbo on a barn door..
    osm
    True... but you end up with one helluva fast barn door!
    Apr 2015
    Chicago
    Are there records kept for the fasted Spyders?
    2019 Rally , Black
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    Yes the sanctioning bodies that run the land speed records for the Bonneville Salt Flats keep them. That all I know about that.
    http://www.spyderlovers.com/forums/s...lle+salt+flats
    This a post from SethO when he ran Bonneville.
    Turbo charger post hope this helps
    I think that Doc's two-run average might have been a bit over 128 mph...
    Dec 2008
    Syracuse, NY
    It was 123.8 mph, according to the link in my previous post.
    I see that those runs were made in 2013...
    I was under the impression that he had gone faster than that. (Although my memory is always suspect! )
    Could he have also gone in 2014, and improved upon these numbers?
    By the way; thanks for digging them up for us!
    Danbury Connecticut
    Do I recall correctly? There were some serious reliability issues with these engines?
    IBA #47122
    2020 RT Limited Asphalt Grey
    Mar 2012
    NJ
    Quote Originally Posted by ThreeWheels View Post
    Only when trying to turbo them. The design just isn't a good turbo setup.
    Sent from my SCH-I545 using Tapatalk
    As I recall; Doc mentioned that the tuning for them needed to be... perfect!
    Very Active Member AMTJIM's Avatar
    Jun 2008
    Vail, AZ
    It would be nice to be just a little quicker and hit redline in fifth without a struggle, but you are so close without the turbo already. He's trapped with the confines of a low geared 5 spd transmission, even with 6th, one of those larger pulleys that were available and a thinner larger diameter tire that is available...still 140~145 everytime. Serious crank and piston rework along with a seemingly endless gearboxand/or pulleys would be needed to break free of the Spyders limits.
    In the twisties I was playing the tart...
    2009 GS SM5 , Red/Black
    Mar 2012
    NJ
    Aprilia aprilia aprilia. .... answers all the questions and is much quicker and painless than messing with turbo tuning a motor that isn't designed for it.
    The bottom end and gearbox are more than stout enough.
    Drew,
    Didn't one of your buddies build the Aprilia ?
    If you could get us some details and pictures of it...
    Jun 2008
    Vail, AZ
    It doesn't matter, the crank is the usual weak spot like so many sport vtwins. You need a serious gear ratio/ final drive change or you will always be confined to to the same low speed redline wall. It won't take something with as much output as the aerocharger had to get you there, the spyder gets so close as it is, maybe 2psi max to be a little quicker and hit redline in 5th no problem.
    Mar 2012
    NJ
    Drew,
    If you could get us some details and pictures of it... [emoji106]
    Yes he did. He figured the motor with minor tuning was right about 150hp. (It's 141hp stock). Last time I talked to him he was in the process of gutting the gearboxes and going back to the 5spd sprder gear box innards because he wanted reverse back and something different about the outputs???? He said top speeds were obtained in 5th gear and it would wind up to 10k. 6th offered no higher speed that he could feel, only lower revs. I'll let you math junkies figure top speed as the speedo doesn't work.
    I can try to get some pics next time I see him but other than an aprilia cluster mounted in the spyder hole and a few missing misc parts, it doesn't look any different.
    Mar 2012
    NJ
    Quote Originally Posted by AMTJIM View Post
    The crank and gearboxes are far from being weak points on this platform. Remember, the same motor and basic gearbox pieces are run in the Aprilia bikes with the rsvr factory running 141hp. This was an off the shelf track bike.
    BRP really detuned the platform for the spyder.
    It's just not a good motor for forced induction Something about ring placement???
    Jun 2008
    Vail, AZ
    That may be true, but they aren't pushing 850 to 1100 lbs on those...way different. They can say that all they want like many of the other reliability claims they made with the Spyder. Spyders have had all sorts of transmission issues since release, front pulley shears being a big one.
    Mar 2012
    NJ
    I would love to see documentation to all those failures. ....thanks.
    A few sheared pulley bolts because of improper torque or a bolt working loose is not a weak area, it just happens, and seemed to be more of a topic on the early models. Not an issue for many years. Thats not really a weak trans or crank issue anyway.....A full trans failure?...
    Mar 2012
    NJ
    I think if we were going to talk about weak links on the spyder Jim, electronics are the first area to come to mind....lol.
