Results 1 to 10 of 10
    Dec 2013
    South Africa
    Default Brake pads change
    Hi,
    I need to change my brake pads on my 2010 RS. Is it something I can order from eBay (or different place) and change it myself. In the manual it says brakes need to be changed by the dealer, but I am keen to do it myself. How easy is it? Can someone point me to the correct stuff to order?
    Thanks!
    Default Sure..!!
    go to our sponsor BajaRon and he can set you up with what you need to make the change. If you have one great if not get a shop manual online like Green manual off ebay to help...good luck...you will do fine...
    ​2012 RS sm5
    Invalid Emails
    Oct 2013
    Dardenne Prairie, MO
    You can purchase the BRP Service Manual from www.brpmanuals.com. It is in pdf format so you can print the pages you need for each service or repair.
    2014 RTSS , Cogna/ black
    Invalid Emails
    MT Tabor VT
    Easy to do if you've done brakes on a car. Just be very careful with the clips that hold the brake pads. They break very easily. I had to make a new clip out of a spring I had in the tool box because I was a bobo and broke one.
    Dec 2013
    South Africa
    Thanks, can anyone send me a link for the brake pads? I can't seem to find them...
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Dec 2013
    South Africa
    Thanks!
    Very Active Member Texmac1011's Avatar
    Aug 2009
    Granbury, TX
    Quote Originally Posted by terminal3k View Post
    Hi,
    Thanks!
    Courtesy of Arntufun. Video #10 will tell you everything you need to know to change the brake pads.
    http://www.spyderlovers.com/forums/s...ghlight=brakes
    Ryde Safe!
    "There are two things you can never get back. A word after it is said and time after it is gone."
    Dec 2013
    South Africa
    Quote Originally Posted by Texmac1011 View Post
    Thanks, that will definitely help a lot. Saves me buying the manual.
    Very Active Member Flanker's Avatar
    Apr 2013
    Michigan
    I bought and installed EBC pads from Bajaron. Stop great; though I skipped the red goo step on the back of the pads he recommended............................... the s do squeak!
    2018 F3 S, BRP SS Grill, Spoiler, Attitude Bars, #1 linkage kit, Chopped R Fender, TBR S1R slip On exhaust, Elka Stage 2 R Shock, Shad saddlebags
