Results 1 to 11 of 11
Thread: front tires??
    Registered Users rock's Avatar
    martinsburg,west virginia
    Default front tires??
    HELP!!! need front tires for our 2010 rts-se5..what tires are best...so many brands..vreestien, federal, bridgestone, dunlop, michelin, achilles, nankang...i am so confused..can i use 4 ply..do i need high speed..omg...
    gary (τΏτ)
    2010 can am spyder RTS-SE5 limited... #0058
    timeless black
    lighting by .......Big Dog Productions
    pin striping by..Letterfly
    exhaust by.......Spyder1attitude
    strobe brake lights by...Custom Dynamics
    K & N air filter
    You're going to get a WHOLE bunch of different options from this crowd...
    Why don't you like the OEMs?
    While I'm not their biggest fan; I did get over 17,000 miles out of a set of them.
    Bridgestone, Michelin, Toyo; all get lots of good press in here.
    Have you checked with your dealer to see if they'll mount an automotive tire on a rim for a Spyder? Some will, and some won't.
    Now; let's wait for the tire experts to show up...
    SpyderLovers Sponsor scooterexpress's Avatar
    Mar 2012
    ft-worth texas
    i have yokohomas they ride smooth.2011rts
    Tall flag mount, spyderpops skid plate & stainless steel screen mesh, airhawk adjustable cushion, raised white lettered tires.
    Default Not going there..!!
    There are no end to threads on this...my oem tires have 18,000 miles and look new. Great offers for them on ebay and new Vee-Arachnid's are here as well for motorcycle use directional...if your confused now it will get worse..good luck..!!
    ​2012 RS sm5
    Active Member sinkhole's Avatar
    Jul 2010
    Huntsville, Al
    Default Front tires...
    I have 28k on the original front tires of my 2010 RT, running 22psi... and they still look "new".
    Dave
    Never leave well enough alone! (Raymond Loewy)
    Very Active Member BikerDoc's Avatar
    Clermont, Florida
    I had 43243 miles on my 2012 OEM tires when I traded the RT LTD in, and my guess is that they had another 5000 in them. These tires can perform well if you bike is well aligned and your tires inflated well above BRP recommendations. I am not at all a gentle rider so this is great wear.
    220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
    Also a user of the OEM tires. Got 23,500 out of my last set of fronts.
    Registered Users eagle's Avatar
    Dec 2010
    benson,mn.
    Default tires
    I had 40,000 on the oem front tires on my 08 GS. These seemed to be quite round and well aligned. On the other hand, on my NEW 2012 RTs I got last May, I had to put a set of Cooper CS3 tires on, I do really like these, as the OEM tires very out of round = even had one replaced under warranty but still not good enough. OEM tires are fine IF lucky to get some round ones. Also==== ALIGN == ALIGN == ALIGN. One of the BEST things to do for your Spyder.
    Default ALIGNMENT = TIRE MILEAGE
    A couple others have just said this ( read above ).............But these statements actually come from GOD.....if your tires are not in some way defective the thing that matters the most is ALIGNMENT ALIGNMENT ALIGNMENT ....any tire you put on will get great mileage, and some of the automotive tires will get incredible mileage butonly if it's accurately aligned............so get it LAZER ALIGNED , IT'S THE ONLY WAY TO GO.......Mike
    i was just wondering if i could get better miles from car tires...we have 31,000 on the oem front tires...how ever they are starting to cup and causing a vibration...we got 29,000 out of the rear and put kumho car tires on it...there was no uneven wear on the drive or front tires..will 4 plys give me better wear?? the only problem i have seen is unless i get oems from the dealer...most places will have to order such a unusual size since it still uses 165-65-14...i am still considering oem s from the dealer and he has them in stockk...
    gary (τΏτ)
    timeless black
    K & N air filter
    May 2013
    SW MO
    It's hard to argue against OEM front tires with that kind of mileage.
    Silver Shadow
    2013 RT-S Lamonster Edition (vented windshield,
    NBV highway pegs, Two Brothers exhaust)
    Additional Mods: SpyderPops BumpSkid, Elka 1+ shocks, BajaRon Anti-Sway Bar
    A Veteran is someone who, at one point in his or her life, wrote a blank check made payable to “The United States of America,” for an amount of “up to and including my life.”
