If the discount is big enough (say 3K or more), and financing incentives are aggressive (2% or less), I'd probably do 13.
...in the pink (Girls On Spyders)
If you go with a 13...make sure the recalls and service bulletins have all been done....front end wobble... stability links replaced, if #4...master cylinder/canister recall...are there any more or is that it?.....good luck and enjoy no matter which way you go
