SpyderLovers Founder
2013 Stabilizer Bar Link Rods (FYI)
If you have a 2013 Spyder and you want to check your links to see if they are part of the bad batch here's the info.
Thanks. Is this a service bulletin?
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Good to know..!!
thanks for keeping us ahead of the curve...
2012 RS sm5
Not agian.
Thanks for the info Lamont.
Now I have to lay on the concrete floor and look at those links again. I just did that yesterday.
2018 F3 LIMITED
I just received from BRP a link with CCV1 3, which I had ordered so that I would have a spare for my 2013 RTS SE5. Based upon your information, this would not need to be replaced. However, both of the swivels were stuck so hard that I could not move them with my hand. I had to use a screw driver to break them loose. After oiling them I can now move them with my hand. Did BRP indicate what was wrong with the earlier links? Am I wrong in thinking they should move freely with my hand?
SpyderLovers Sponsor
Not speaking for Lamont, but the OEM links have very tight Heim joints. Probably because they are a composite plastic and they need to be tighter than typical metal to metal or metal to nylon Heim joints. If you can move them reasonably easily with a bolt or screwdriver through the hole I wouldn't worry about it.
However, over time these joints can get pretty loose (could be wear, could be fatigue of the composite plastic). I pulled the OEM links off my 2008 GS (32,000+ miles) and the balls were loose to the point that there may be some slop in the ball and socket when under stress.
Thanks for the info.
2013 ST-S SE-5 ("Quick Silver") Is her Name
My Mods:
I Have Added the AM/FM Stereo and an Ultimate Seat, with Ryder Backrest, Power Sports wraps." Break Strips" Kit, GloRyders with the Spyder Cap, Fox Racing Shock and Anti- Sway Bar Kit, Spyder Pops Bump Skid, Spyderlighter's LED Running Light Kit With Fender lights. Cal Si Shorty Smoked Windshield, The 2014 Side Panels, Lamonsters Cat Delete, And an Akrapovic Sport Touring Exhaust.
La monster comes through again
See Lamont relieved everyone's mind again. I feel good about my SWAG being on target too. I got lucky!
Now we can sit back and wonder what will the next crisis be? When will it strike?
Is there an easy way to check these?
Just curious where did you get this info from Lamont before I school my service dept (again).
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
need help
Can someone please tell me how to check this? I do not know what panels would need to come off to see this part. Thank you! Jill
No panels need to be removed but you will need to raise your Spyder's front end and crawl under it to see the links. Search for other posts on this subject and there should be some posts with pictures that show the location of the sway bar links.
2016 F3-L Special Series? Mods: Lamonster IPS end caps w/ Gripper 3rd pegs, GPS mount, Power Plate, Perf. Muffler; Backoff Brake Light Strobe; CD Front (amber/red) Brightsides & Tip Kit; ISCI Flag Holder w/Long Poles; BRP Signature Light, Aux Lights, Saddlebag Liners, Garmin 590 GPS; TricLED foam Grips, LEDs (Aux/headlights); Pitbull Driving Lights; RDL seat; Ultimate backrest
Previous ryde: 2012 RT-L, 26,636 miles on it when traded; 2014 RT-L, 34,147 miles on it when traded
From the big boys at BRP. You can take this info to the bank....
Thanks Ron had to tell them the p0127,p0217 stories since BRP hasn't put that info out to the dealers and I just wanted to make sure. It is what I thought though.
Yet another piece of information to in our Spyder arsenal.
Carl
2012 White RT Limited and 2013 Yellow ST-S Think 3 .i.
GOS Founding Member (Girls On Spyders)
This is a recall on some models according to BRP the bulletin number is 2013-06 I just talked with them and mine is included . They say it is stabilizer link inspection. Don't know if that means just inspect or replace but I assume the above information will be the determining factor.
Just checked the one I could see "4" with no white dot dam replace.....
Banged Up Member
Had mine replaced today. Took about 15 minutes and no charge. I was on my way in no time.
Chris PS: Edit: [It wouldn't be a bad idea to call your service department first and making sure they have the part before running down there to change out.]
PSS: Your dealer will know your Vin# and can find out via their computer whether you need this change or not.
...in the pink (Girls On Spyders)
My links are different...one is a 4 with no orange dot...replace and the other is a 2 with no orange dot...do not replace.....I'll replace both thru Baja Ron resize1.jpg resize2.jpg
#IamARyder #RideASpyder #CanAmSpyder
Oh no, now i am in trouble again ........................... one of mine had a 3 and one had a 2, i replaced both of them with the metal ones from Baja Ron ................. (the note says do not replace) . How much trouble am I in?????
Cruzr Joe
Cruzr Joe
