HELP !! HOW DO YOU REMOVE THE THE REAR SIDE PANEL FOR 2011 SPYDER RT
I may need to access the battery and in order to do this I need to remove the "Rear Side Panel". I have read the instructions from the owners manual, but I do not have the tool to remove the two "Silver Screws" attaching it to the "Top Side Panel" ( The tool did not come with the tool Kit). Also do I need to take off the "Top Side Panel" completely in order to remove the "Rear Side Panel". I have a heated Corbin seat and left it on. It ran the battery completely down and I am having trouble Jump Starting the bike. Do I need to put the battery on a charger or do I need to replace the battery. Thanks
Motorbike Professor
Why are you having trouble jump starting the Spyder? If it is because you can't access the battery terminals, remember that there are jump start terminals accessible under the seat.
Be aware that you may not be able to charge a fully dead battery with a Battry Tender or similar charger. They need to sense some battery voltage before they work. If that is the case you will need to hook up a second battery along with the charger, until the Spyder battery is charged enough to allow the tender to work, or you will need to use a standard battery charger first. If you use a standard charger, don't charge at anything above 2.5 amps or so, lest you damage the battery.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
SpyderLovers Founder
Like Scotty said you will need to use an old style charger to restore a completely dead battery. There's no need to remove the panels or battery to do this. For sure you don't want to try and remove those security torx screws. Here's some videos that may help you if you ever do have to remove the panels.
http://www.spyderlovers.com/forums/s...f-and-on-video
Oh and
Motorbike Professor
-Scotty
Forum
RT Shop Talk
