SpyderLovers Founder
GPS unit
Originally Posted by Lamonster
Got a bunch done on the RT today. Got all the chrome on and moved my GPS and got the fender lights installed. I'm really happy with the way this thing turned out. Just waiting on my Corbin seat and it will pretty much be done.
now that you have your 665 mounted ...... I will be waiting on your Report on function vs the 660. especially the Xm...... thanks for your efforts from all of us........ I can only hope "soon " I will have my 1st spyder ..... it just over the next hill and around the bend.........
Howard
Originally Posted by canam9
Lamont, outstanding Setup. Most Rad!
Would it be too much to ask for the RAM list of parts you used to mount the 665.
Thanks again for all your help. You Rock!
You'll need 2 of these
http://www.ram-mount.com/CatalogResu...5/Default.aspx
and one of these if you want chrome
That is one beautiful machine!
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
RT-S PE#0031
I see you decided to go with the LED Front Mud Flap Replacement Kit. You had mentioned in an earlier post that you weren't sure about adding them because of video issues with them. Looks great!
Mark & Mary Lou Lawson
Snellville, GA USA
'10 RT-S PE #0031
'10 RT-622 Trailer
'08 Yellow SM5 #2332
'01 Black GL1800A Goldwing #0930
"Remember in the darkness what you have learned in the light." - Joe Bayly
I'm not sure about hooking them up into the triple play because of the video. I think I'll set them up as turn signals but not brake lights this time.
Motorbike Professor
How about just putting a switch on the mudflap lights, so you can kill them when you video?
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
That is an option I thought about. Last time I just put some black tape over the lights when I was shooting with the BRP road crew. I may just do that though seeing I'm running out of things to do.
Question
Where did you get the fender lights from and mud flaps????
Also how is your GPS mounted to the dash?????
check home page sponsers and you'll find them with a couple of vendors.
Happy Spyderlovers
Mouting GPS to Dash
How did you mount the GPS to the dash? I saw the same question but didn't see a reply and that is probably I am not versed in blogging. Did you have to take the dash apart.? I want to do this MOD. I think the only variation I am going to do is add a sun shield that goes from the dash to over the GPS to give better viewing in the sun and to hide the mount as you look from the frunk thru the windscreen. Thanks in advance for any guidance.
