Originally Posted by NancysToy
'O Crap Kit
Body screws
Plastic rivets
Oil change O-rings
Drain plugs
Brake light bulbs (RS)
Rubber grommets (RT)
Mirror inserts (although I have never broken one)
Touch-up paint (added 2/28/11)
What else?
Dehydrated fuel tablet...just add water?
Relays.
When I had my 600 mile checkup done by my private mechanic (ARRR), he discovered that the slotted plastic dohickeys on the top of the mirror were broken...both sides. Apparently whoever assembled my RT slammed the mirror in at all 3 securement points and not down and in. There were other issues as well but all minor. I'm not sure if the plastic is put on at the dealer or the plant but they did a messy job.
Happy Spyder Owner
States visited on the Spyder.
And if we live life without a passion, then we're not living.
Originally Posted by Desert Spyder
Relays....
Got it, and I added fuses of both kinds, too.
When one of you veterans strip your RT down could you do a video of the plastic removal ?Where is Silver Surfer - he promised !!!!
Reason: .
SpydermanCT
2010 RT-S SE5 Timeless Black PE # 794 ~ RT-622 Trailer ~ Can-Am Garmin 665 GPS ~ Elka Front Shocks ~ ESI Brightsides with Rips Kit ~ ESI RT Fender Tips Kit ~ Rear Brightsides ~ HMT Brake Light ~ Tricplate rear running / Brake LED's ~ ESI Mud Flap Lights ~ LED Day Runners ~ Right Side Inlet Covers ~ Street Magic Scuff Guards ~ IPS Key Cover ~ KewlMetal Kewlocks ~ Spyderpops Radiator Block Off Plate and Catalytic Converter Shield Set ~ Carbon Fiber Kit ~ Corbin Seat
There is a bulletin from Can-Am explaining how to glue the rubber grommets in place. Does anyone have a copy or tell me where I can find it? My biggest frustration when reassembling the body panels is the grommets push through in a few places. I use dry silicone lubricant on the grommets, which helps, but is not a fix.
Bob H - Derry, NH
2020 Spyder RT Limited - Petrol Metallic Blue
2010 RT622 Trailer and BRP Hitch
BRP Vented Touring Windshield, BRP Backrest
Garmin 590 with BRP Mount
Fobo TPMS for Spyder and Trailer
Lidlox, Blue Sea Fuse Box for power distribution
Ram Ball Mounts for Radar Detector, Cup Holder and Phone Holder
Sena 20S / SL2 Headsets, Foam Grip Covers, Belt Tensioner
BAJA Ron Sway Bar and Shock Adjusters, Heli Bars
The rubber grommet service bulletin 2010-6 is linked on the home page(listed as 2010-7).
I tore my Spyder down this weekend to install my new Elka shocks. As expected I tore one of the rubber grommets that hold the panels together. I noticed that some of the grommets are round and others are oval. When I look at the illustrated parts breakdown, only one type of grommet p/n 750005156 is listed. Even that part is not available on the Can-Am website. I have the spare round grommets, but need the ovals. Does anyone have the correct p/n and know where I can order these?
Bob H - Derry, NH
A fellow spyder lover pointed me to this site where I order a pack for spares.
http://www.directlineparts.com/produ...pid=2245&str=4
Good luck C-YA RL
