Page 1 of 2 12 LastLast
Results 1 to 25 of 26
    Apr 2023
    Red Deer, Alberta
    Default Are 2020+ Trailer Hitches longer than older models? If so, how much?
    I was informed today that the 2020 and newer Spyders use a longer hitch than older models. Just wondering if anyone knows how much longer the newer one is?
    Last edited by Peter Aawen; 07-17-2023 at 11:48 PM. Reason: Expanded title to briefly ask the question/s... ;-)
    2022 Spyder RTL Marsala Red Chrome
    Bossier LoUiSiAna
    Sorry only heard of rear axle maybe hollow or some maybe not. Good question though will be keeping eye out.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Active Member Bob L's Avatar
    Oct 2014
    Massachusetts
    When I ordered my 2022 I asked Pierre at CanAmSpyderAccessories if I could transfer my hitch from my 2014 and he said no, the new ones are a bit longer. But I do not know how different.
    Bob L.
    Worcester County Massachusetts
    www.rk-mass2.org
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    I moved the hitch from my 2016 F3L to my 2020 RTL and it works great. My hitch isn’t OEM but that does not matter.
    I guess you are asking if pre-2020 RTL hitches will transfer to 2020+ .
    Love my Spyders
    2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
    2014 RTS Circuit Yellow purchased 3/2/2018
    2020 RTL Petrol Blue purchased 1/27/2023
    Girls on Spyders #3195
    No more 2 wheels
    2020 RTL , Lamonster floor board riser Petrol Blue
    Dec 2020
    Hartwell, Ga
    I put one from a older Spyder onto my 2020 RTL with no problems. The wiring harness won't work but the hitch will.
    Nov 2015
    Chardon, OH
    Here’s a thread with useful info.
    https://www.spyderlovers.com/forums/...is-information
    Doug
    ”Freedom is not a loophole”
    Apr 2023
    Red Deer, Alberta
    I have the BRP hitch from my 2012 and installed it on my 2022. Fits just fine except the ball contacts my license plate when the suspension travels up. I have adjusted the air bag control valve for more air pressure but it still hits the license plate.
    Pierre @Canam Spyder Accessories told me the 2020 and up RT’s need a longer hitch to mitigate this issue but I see on that website the aftermarket hitch fits them all. What is the difference?
    Dec 2013
    Quote Originally Posted by 2old2fly View Post
    Your wallet's a few hundred $$ lighter....
    Juuust Sayin'
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Nov 2015
    Chardon, OH
    The ball hits the license plate? I kept my 2012 hitch. Didn’t put it on yet. I was only focused on the swing arm and the mounting. Guess I’ll have to check on that. Thanks.
    Doug
    Apr 2023
    Red Deer, Alberta
    Juuust Sayin'
    Meaning what?
    May 2013
    Apex, N.C.
    Quote Originally Posted by al0vely View Post
    This is good to know, since I am thinking about taking the OEM one off my 2016 F3L and putting it on my 2021 RTL. I see a previous post said something about it hitting his license plate, do you have this issue?
    Dec 2013
    Juuust Sayin'
    Meaning what?
    Meaning the only real difference is that if you get one of the 'longer hitches', you've had pay for ANOTHER hitch, making your wallet a few hundred $$ lighter!
    Nov 2015
    Chardon, OH
    Quote Originally Posted by blacklightning View Post
    Well, I went out and checked. Now, mine is an OEM hitch from 2012. Part number on the hitch of 705203210. And sure enough, the ball sits right underneath the license plate. So, when you account for the trailer coupling, and riding 2-up and loaded, I can see how it will hit the license plate area when you ride over the bumps. So, that's why the new hitches have to be longer, and why the after-market hitch - which apparently always was longer - doesn't have an issue. The longer hitch moves all of that further back and it clears.
    So, it's not about the swing arm and the bolt. It's about interference with the license plate body parts when you go over the bumps. Too bad. Guess I'll have a trailer hitch for sale. (That nobody will want)
    Doug
    Apr 2023
    Red Deer, Alberta
    Who said I am buying another hitch? I am asking how much longer the newer hitches are so I can make mine that length.
    May 2013
    Apex, N.C.
    Quote Originally Posted by Snowbelt Spyder View Post
    Thank you for that information. I would have use for the hitch only 1 time a year, and that is not a certainty. So I guess I will stick with what I have. Or I might check the one on my F3L against my buddies on his 2020 RTL. It might actually be longer anyway due to the newer RT and F3T and F3L all having the same type of setup on the rear mud flap.
    Nov 2015
    Chardon, OH
    You could probably eyeball that for yourself. Whatever you’d be happy with, since you’re doing it DIY. Looks like anything like 4 to 6 inches gives plenty of clearance. That is, if you want to go through that modification. Your call. Myself - I think I’ll go the plug and play route. Good luck. And thanks for bringing that up. I never would have noticed that until it was too late.
    Doug
    Apr 2023
    Red Deer, Alberta
    I think that's the route I may need to take. I guess with the small load the hitch takes length is not a big issue.
    Mar 2013
    Maumelle, AR
    I have the BRP hitch on my 2020 RT Limited. The one that's been on all my Spyders and it fits just fine. The top of the ball sits eight inches below my license plate.
    2020 RT Limited , Chalk
    Apr 2019
    Clinton, MS
    Pic's would be nice to help end the confusion.
    2019 RTL Phoenix Orange
    Dec 2020
    Hartwell, Ga
    I have no issue at all with mine hitting. When I pull my trailer, I am always riding two up.
    Apr 2023
    Red Deer, Alberta
    Quote Originally Posted by K80Shooter View Post
    Do you know the air pressure in your air bag when loaded? That may be part of my problem.
    Apr 2023
    Red Deer, Alberta
    Quote Originally Posted by Copperman View Post
    Mine does as well.
    Dec 2020
    Hartwell, Ga
    I do not know right off hand but will look the next time that we ride as I have the Fobo-2 installed on it also. The ride height is determined by the amount of weight on the spyder, but I can see how it would change by hitting a speed bump or something like that. I am wondering if your compressor, valve and stuff is working correctly.
    I had honestly thought of raising my ball up a couple of inches to level out the trailer more.
    I did check and the hitch that I purchased used from this site came off of a 2014 model and is the BRP hitch.
    Apr 2016
    Indiana
    No contact with the license plate for me.
    Love my Spyders
    No more 2 wheels
    May 2013
    Apex, N.C.
    I am going to check mine for measurement. I am guessing (only a guess), that the F3T and F3L is the same measurement as the one for the 2020+ RT. Especially since the rear is made so similar.
