Results 1 to 17 of 17
    May 2017
    Mesa, Arid-Zone-A
    Default 2020 RT Trailer Hitch mis-information
    I have a riding buddy who picked up his new 2020 RTL today. He has a Freedom trailer so needed a hitch installed on his new bike. At first he was told hitches for the 2020s were not yet available. Upon further investigation, it was discovered that the 2020s take exactly the same hitch as previous models. The dealer transferred the hitch from his "old" 2015 RTL to his new bike. Some of you new 2020 owners and potential owners may find this useful..... Jim
    Semper Fi
    Mar 2015
    Brockport, NY
    Good info to have. Joe and Ann have also done a swap out and found the same results
    2014 RT-S Pearl White
    Idaho
    Quote Originally Posted by canamjhb View Post
    Was the harness reusable as is? Others will want to know.
    2014 Copper RTS
    May 2017
    Mesa, Arid-Zone-A
    My friend has a new harness on order. I don't know if the new harness is required because it may be different or if the dealer was too lazy to take it off the old bike and put it on the new one. But the hitch does indeed fit. I saw it today. First 2020 I've seen and I was impressed. BRP did a lot of good things and I believe it is a winner. Another interesting point is he got a full 7-year warranty at a cost of $1,300 additional. Seems very reasonable to me. My bank account is starting to get nervous..... Jim
    Semper Fi
    Active Member jredman's Avatar
    May 2013
    Caddo Mills, TX
    That is so good to know. I was never going to pay $669.95 for a darn hitch from BRP.
    2020 RT Limited , Chalk White
    Sep 2014
    USA
    I believe Captjim posted that the previous model hitches do work on the new Spyders
    Active Member rick_w's Avatar
    May 2013
    NE Ohio, Madison
    The Harness for an F3T/LTD will work. Connectors in rear are different then previous RT's but same as F3 LTD.
    Rick
    Spyder Lovers Vendor
    Value-Accessories
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by rick_w View Post
    That really stinks! I sold my hitch off my F3 Limited when I knew I was getting a 2020 RT Limited. I just assumed it wouldn't fit. Oh, well.
    Very Active Member bodymanpainter's Avatar
    Dec 2009
    Yulee, Florida
    Quote Originally Posted by Copperman View Post
    I did the same thing, oh, well live and learn.
    Toby
    2020 RTL
    Nov 2018
    Virginia
    Be careful of the changes in the harness due to year of manufacture. I bought a factory harness for my 2018 F3L on line to save a few bucks. It turns out it was for a 2017 and there was an incompatibility for one of the connectors. BRP changes part numbers at will and doesn't send info to the dealers. So, after the parts man at the local dealer and I starred at the parts list for a considerable period of time I bought the "jumper" section that appeared to be different and, low and behold, it fit! The research was a pain in the butt but it only cost $35 for the part.
    The point here is be careful of what year harness you may try to use from any of these bikes. They are not universally compatible.
    2018 Can Am Spyder F3L, 1995 BMW R1100R, 1988 Suzuki GS250, 2019 Ryker 600 (Wife's)
    Mar 2013
    if this is true then the parts needed are
    710003903 Module
    710005823 Module Harness
    710004851 Trailer Harness
    Also the rear fender extension that is on the 2020 RT may need to be trimmed on the right side as it may make contact with the hitch. It did on my 2018 F3L. The hitch assembly that BRP sales for the F3 comes with a new extension that has a cut out. I just used a box cutter to do that.
    Here is a link to look up install instructions
    https://instructions.brp.com/e-instruction.html
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    May 2013
    Caddo Mills, TX
    I can confirm the Show Chrome trailer hitch works perfectly on the 2020 RT. I did have to tap out some holes to get all 3 bolts on each side. Were not tapped very well or not clean. But perfect fit other wise. Just fit right over the axle, not pushing on from behind like I saw of some older videos. Now I just have to find a compatible Wiring Harness. The Show Chrome is not compatible. Totally different connectors.
    Idaho
    Quote Originally Posted by jredman View Post
    Won't this one work? I understand the rear light harness on the new RT is the same as F3.
    http://www.bigbikeparts.com/template...GroupGuid=9230
    2014 Copper RTS
    May 2013
    Caddo Mills, TX
    That is exactly the one I bought. Different connectors, do not fit. I tried. Totally different plugs. Similar, but do not fit.
    Idaho
    Then I think your next best bet is to buy the RT module harness, P/N 710005823, cut the module connector off. Take the SC harness you have and cut off the leads that go to the rear lights. Connect the 5 wires out of the relay box to the 5 wires of the BRP Y harness. That'll give you what you want. That is assuming the harness connectors under the seat for the trailer harness are the same on the 2020 as previous. The SC connectors go into the rear light harnesses while the BRP Y harness connects into the bike frame harness.
    2014 Copper RTS
    Jun 2021
    New South Wales
    Hi Guys, thanks for the feedback as I also just fitted a Show Chrome 41-164 trailer hitch to my 2020 RT. The only extra tool I needed was a T30 Torq head to release the brake line holders. Instructions stated to remove the rear brake bolt but that's not required if you release the holder. Also instructions stated to wrap the spacers with masking tape if they are loose. Not confident with that option as the spacers should remain on the outside of the axle so I used silicone as they can be removed at anytime. Hopefully the wiring harness is just as easy, just waiting for it to arrive.
    Very Active Member Big F's Avatar
    Aug 2012
    Bellevue, NE
    i'm confused?? I have been told by two dealers that the max for Spyder warranties is 5 years?????? If someone got 7 years it must not be by BRP and/or BEST, right?
    BIG F
