Belt replacement mileage
For those of you with over 65,000 miles on your Spyders at what point did you consider replacing your drive belt? I have 68,000+ on my 2012 RTL original belt and sprocket. If you are still on your original belt what do the teeth look like? How are they sitting in the Sprocket? Is your Sprocket worn,and how did you know?
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
Hi Paul, Your belt is 10 years old. I would be inclined to do a replacement next time it is convenient, like when replacing the rear tire. The belt has served you well. Keep it with you as an emergency replacement..... Jim
Semper Fi
I expect to get 250,000 mi. from my orig. OEM belt...( Unless it gets damaged ).. During riding season it lives in my garage .... in winter it lives in my basement. Only a very small portion of the Belt ever see's the sun, so no ultraviolet is going to effect it ..... good luck .... Mike .....PS someone should ask SpyderAnn how long Her belts have lasted
Thanks Mike. I thought I might be a lone ranger. I check the belt routinely for wear and damage, the only time I get down on the garage floor except for replacing rear brake pads and changing coolant. The same technician has changed all my rear tires and on last change, 200 miles ago gave me a full status report on whole drive system and brakes, all fine. I don't intend to begin thinking about it until I approach 150K.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
I haven't heard from Joe on how Anne's belts go but I have also never heard of them changing one either. Jim I am probably 2 years away from a rear tire change but I have to agree with Mike,other then atmospheric the sun doesn't really reach the belt. I am very encouraged that others are thinking they can make at least 100,000 mi on a belt as that is also my intention. Thanks for all your replies.
Happy TRAils/NSD
Paul
2012 RT L
TRA
PGR
Venturers #78
TOI
If there are no cracks or large chunks on the belt along with proper tension you should far exceed 100k on the belt.
Took me 8 years to put 20,000 miles on my bike. So if the belt is good to 100,000 miles I don’t have to change it til it’s 40 years old.
that sounds good to me. It's taken me 6 years to put 60,000 on it, there were 8000 on it when I bought it. That means I'll have to stay alive and ride it at least 6 more years.
Happy TRAils/NSD
Paul
2012 RT L
TRA
PGR
Venturers #78
TOI
Unless it's in the desert sun all of the time (UV radiation) that belt should last a really long time, like Mike suggested.
2020 RTL SE6
I have a 2008 that only has 20K on it. Bought it 5 years ago an it had 9K on it then. As a desert dweller, we replace tires every three years due rto heat and dry rot potential. I keep the bike 100% covered when not out on it. I have it the belt inspected ebeverytime I have it in for service or the tires replaced. Never a lot of wear on tires, but not risking a blow oy on a mountain pass heading to Flagsatff for a lunch ride. Belt and sprockets look good on my old GS.
Other than UV and direct chemical attack, oxzone is hard on rubber and plastic. O-rings stored near a high voltage source where I used to work all disintegrated from the ozone it produced.
"Love 'em all.... Let GOD sort 'em out!"
2021 RTL Dark Chalk Metallic with comfort seat
1978 GL1000 w/'75 engine show bike
1976 RD400c
New belt at 14,000 miles. Caught a rock somewhere and found a big hole. I hate when that happens !!!
Tommy J.
F3L SE5 Black -- F4 windshield w/wings, Reggie LED headlights, driving lights & Cyclops LED, Ultimate seat, Fox shocks, BajaRon swaybar, Lamont highway centerline pegs & 3rd peg, Lamont belt tensioner, K&N air filter, Baker air wings & cup holder, CanAm hitch.
Tommy J.
Next time…. turn.
Tommy J.
Been there, done that, twice.
Yes, I've heard that. Years ago ribber and plastic items stored in our garages along with freezers and extra refrigerators, disintegrated rapidly. Not so much anymore because they've changed compounds. I guess?
Does this go for most spyders, regardless of year or model that they can go that long technically without issues?
Ozzie Ozzie Ozzie
2013 RT Ltd Pearl White
Ryde More, Worry Less!
