Page 1 of 3 123 LastLast
Results 1 to 25 of 64
    Active Member AraņaRider's Avatar
    May 2017
    Tampa,fl
    Default Non ethanol in the spyder?
    Does anyone put non ethanol in the spyder? Is it better for the spyder ?
    All the time here. There is NO ethanol in Alaska gasoline.
    Nov 2013
    Central Texas
    Anytime I can get it (which isn't often). Good for the Spyder, better mileage to boot.
    Bossier LoUiSiAna
    Quote Originally Posted by oldguyinCT View Post
    https://www.pure-gas.org/
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Active Member mark4Jesus's Avatar
    Sep 2017
    Sale Creek, Tennessee
    Sure do. I have a station that sells non-ethanol premium about 4 miles from my house.
    2013 RT Limited.
    BajaRon Sway Bar.
    Refined Cycle's BPE2 brake pedal extension.
    Pedal Box
    2013 RT Limited , Refined Cycle BPE2 White
    Default I'm with them
    Anytime I can find it...
    ​2012 RS sm5
    Very Active Member kep-up's Avatar
    Nov 2014
    Mountville, PA
    Put "real" gasoline in all my vehicles whenever I can. Much better for all. Never could figger out why we are mandated to put food in our fuel tanks.
    May 2017
    Tampa,fl
    Thanks for the responses. Looks like I should be putting non ethanol in my car as well
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default YES
    YES & YES.....
    i ALWAYS use non-E gas.... many stations here in SoCar now carry it...
    Dan P
    SPYD3R
    The 10% ethanol blended fuels certainly won't harm your bike…
    But whenever I've been able o find straight gas: I get about a nice bump in fuel economy!
    Sep 2013
    Maine
    Thumbs up
    I always use Non- Ethanol fuel!
    Please note that the only mention of ethanol in the Owner's Manual, is to not go past a 10% mix
    As far as Octane: that's a much bigger concern...
    Apr 2017
    North Central Florida
    Quote Originally Posted by AraņaRider View Post
    No and no.
    It was designed to use E10 and that is no "worse" than pure gasoline.......unless maybe it will sit unused for a year or more.
    Apr 2017
    Well you can believe whatever you want but the fact IS that will cost you a bit more overall because the gas with no ethanol in it costs enough more that you won't make up the difference with slightly better gas mileage.
    And as far as your car goes, often the only non-ethanol product is high octane premium which costs a LOT more than regular.
    If it makes you feel better then do it. But there really is no way to logically justify it.
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by Easy Rider View Post
    Some places have E0 regular too. I use E0 when I can get it too.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jun 2017
    Crossville TN
    Default Three BIG Letters
    ADM
    Quote Originally Posted by kep-up View Post
    Nov 2013
    Oro Valley Arizona
    Non Ethanol around here is as scarce as Hen's teeth.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Sep 2016
    dilworth,minnesota
    Default gas
    This conversation has gotten stretched out to long. Every vehicle built now has been designed to run on a 10% ethanol blend. Non-oxygenated gas is for older vehicles and collector vehicles. I have ran my spyder on 10% ever since I drove it from the dealer I've even had to purchase 87 octane when nothing else was available have found very little difference in performance yes I have tried the non ethanol fuel and feel if there is any difference it is not worth the higher price.
    Nov 2014
    Mountville, PA
    And there you have it.
    Aug 2007
    Greeneville, TN
    You will find people on both sides of every issue. And while it is true that modern vehicles are designed to tolerate the negative effects of ethanol fuel. Non-ethanol fuel is always better.
    Whether or not it is better enough to justify the additional cost. That depends on the buyer. Though, to be completely honest. Ethanol fuel only APPEARS to be less expensive. We actually pay more for ethanol fuel than for straight gasoline. You just don't see it because of the taxpayer funded subsidies for ethanol fuel. Without these subsidies, ethanol fuel would be more expensive at the pump than non-ethanol fuel.
    Plus, if you factor in all of the diesel fuel and oil based fertilizers used by farmers to grow and harvest the corn. And all of the energy needed to process the alcohol out of the corn. There is virtually no difference in the amount of pollution. And it ends up requiring more oil to produce a gallon of ethanol fuel than it does to create a gallon of non-ethanol gasoline.
    But that is another subject altogether.
    Dec 2013
    wisconsin
    If you ride your machine quite often, not a problem. If it sits for weeks at a time, use non-ethanol fuel, because it does absorb moisture from the ambient air, When we/I get back from a ride and know I will not be riding the machine for a time, I will top it off with non-ethanol fuel so hopefully I don't have any issues when I decide to start it up again. Just me being "anal" I guess. Mac
    Apr 2015
    Green Bay, WI
    Default Ethanol blend gasoline
    10% is the rule--but like more rules--not followed. Some have significantly more than 10% ethanol. The bright spot of the ethanol E-85 is it's high octane rating.
    The bad news is keep it away from any & all of your home lawn mowing vehicles--leaf blowers, anything without a real fuel pump. Most smaller devices use a rubber type diaphragm pulled back via piston generated vacuum & a spring to return it to it's orginal position. The ethanol will distort the shape of the rubber type diaphragm & you will need to rebuild the fuel pump section every year or two--Newer model equipment handles it better but ethanol still degrades the diaphragm & as I said earlier--several test have proved the 10% is just a general guideline--not always factual.
    If you live in "Cornfield Midwest Land" finding non ethanol may be a challenge.
    I don't have any info on long term use of ethanol in a Spyder but I'd avoid using it if possible. Lots of rubber type components from valve spring seals--etc.
    Darrell
    Feb 2012
    Spring City,Utah
    You have 10 years and over 100,000 Spyders mostly running around on E 10 with few if any fuel reported defects or problems. I have used straight gas and E10 and find no difference in performance and only a mile or two difference in range.There are several stations here that sell pure but I don't worry about it. Ride more worry less
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Apr 2017
    Quote Originally Posted by Wildrice View Post
    Some what has more than 10% ??
    I assume that you have proof of that claim.....(NOT).
    The high octane rating of pure ethanol isn't much of a "bright spot" since is has significantly less energy content.
    Some drag racers like it.
    South America seems to like it.
    Pretty much nobody else does.
    Sep 2017
    Durham,Maine
    Your very lucky for that!!
    2012 RTL , Pearl
