Results 1 to 9 of 9
    Active Member SpyderBears's Avatar
    May 2016
    Chesterfield, MA
    Default Side compartment won't open
    Having trouble getting the left side compartment to open on our 2015 RTL. We've always had to lean against it and push in while lifting the latch, but now even that doesn't work. Right side works perfectly.
    Hoping its a quick fix. Any ideas?
    Thanks!
    Nate and Lori
    2021 Spyder RT Limited--Deep Marsala Red--Chrome Edition
    [/B]​Nelson-Rigg half cover, Hopnel side bags and trunk liner bags, , Driver's Backrest, BRP Trailer hitch and control module, 131 DB horn from TricLED, "Shadow" trailer from Mini Trailer USA,
    First: Try pushing in against it a little bit more firmly...
    If that doesn't do it: you'll need to get creative.
    That back panel of the bodywork needs to come off.
    But you need to open up the side compartments in order to do it!
    I suppose that you could get it loose on the top and the right-hand side, and see if you could gently massage it out of the way enough to get to the adjusters...
    Good luck!
    Sep 2012
    Stetson, Maine
    In my owners manual, under maintenance section, it tells you how to open side compartment.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Sep 2012
    Stetson, Maine
    New to Sue and I
    It may need a cable adjustment. I had my dealer do mine. Quick, easy, and they did not charge me for it.
    Bossier LoUiSiAna
    If & when is opened, adjustment & cable lube
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Jul 2010
    Las Vegas, NV
    Default Side case
    Nate,
    open trunk. Peer thru the opening while you pull on the latch for the side that won’t open. Find the cable the latch pulls on, and using needle nose pliers, pull another mm or so until side case opens. Now remove the 8 screws that hold the panel on that surrounds the latch. The cable has an adjuster. Turn counterclockwise until the case opens easily. Lube everything with silicone spray, put back together. Call me if you need help; I’ve done plenty! Joe
    Joe Meyer
    May 2016
    Chesterfield, MA
    Quote Originally Posted by cptjam View Post
    Nate,
    Thanks Joe, i found the adjuster and adjusted it. i think i need to readjust to get it just right though. Thanks to all for the great help.
    Nate and Lori
    Jul 2010
    Las Vegas, NV
    Default Sweet!
    Glad to help! Hope to meet you at Spyderfest! Joe
    Joe Meyer
