Results 1 to 7 of 7
    Active Member Stridersr7's Avatar
    Feb 2018
    SC
    Default Speakers and audio unit on a 2009
    So I see on my dash there are vents on the left and right. Is this just for looks? Wondering about putting indoor outdoor radio and speakers on it with Bluetooth and thought that might be a good spot for the speakers. What do you all use and do you have pix of it?
    Default RADIO / STEREO
    Quote Originally Posted by Stridersr7 View Post
    I had an 09 GS, and added a " Shark " audio system to it....... cost about $100.00 ...... It's radio function was poor ( bad reception ) but I only used it to stream music via my MP-3 ............... very good system and cost effective ....... Lamont used them on His wife's 2015 F-3 which had the same structural limitations as the GS ............. good luck .... Mike
    Feb 2018
    SC
    So tj comes with speakers? Wonder where best place to put them. Also just doing Bluetooth to phone was fine?
    Default AUDIO
    .........." tj " ?????? .......... I have no idea what that means ....... Mike
    Feb 2018
    SC
    Idk why when I tried to say “it” it came out as TJ
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    I found over the years the add on systems do pretty good till you pass 70 mph. My best system to date is a Sena SM5 which has blue tooth, phone, and also a built in FM radio. Can hear my speakers great in my helmet. They make several different types depending on what style helmet you wear. Of course you may live in a state that doesn't require a helmet. Even if they did away with the helmet law I would still wear one.
    David
    Active Member Huked's Avatar
    Mar 2017
    Watford City, North Dakota
    Default Shark Audio
    Yes they can come with speakers, they have several types. Just do a search for Shark audio and check out their website. You can also do the same search here and get some ideas including pics of some install ideas.
    This is an F3 but you will get an idea.
    http://www.spyderlovers.com/forums/s...o-on-Spyder-F3
    2019 RTL
    Farkles
    BRP Comfort Seat.
    Foam Grips
    Lidlox
    BRP Passenger armrests
    Baja Ron Anti sway bar
    Lamonster's upgraded BRP vibration damper.
    2019 RTL , Asphalt Grey Metallic Dark
