Results 1 to 17 of 17
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    Default I think the rear suspension system of my 2011 RT ltd does not work
    Good morning to all.
    Here again with my existential doubts cause I think the rear suspension system of my 2011 RT ltd does not work.
    When I press the button to increase or decrease the pressure, I do not hear the pump start even if the "manual" error does not appear on the screen and everything seems to be fine.
    A few weeks ago I put air directly to the shock absorber from the Schrader valve but it seems that it has come down again.
    I thought that once the shock absorber was inflated, the system maintained that pressure when the sensor noticed that the level had dropped but in my RT none of that seems to be working. It isn’t?
    Do you have any procedure to verify?
    2018 F3 Ltd. , Black/Dark
    Nov 2016
    Ooooopppppssss. I'm sorry.
    I think I did not search very well on the forum, cause I couldn't find answers for my "new existential doubts" but I finnally found something that could be ussefull to me.
    Dec 2013
    Don't forget that the compressor will ONLY work if the engine is running & the trans is in gear (well, you've effectively gotta be ryding it or nothing happens!!)
    That 'Manual' warning will come up if the air bag pressure gets too low for whatever reason; if the compressor dies or stops working; or if the height & load sensing valving stops working.... it's basically a 'catch-all' warning for tghe ACS!
    So you need to check all those things - the engine running bit is easiest; then having some air in the bag; & only then do you need to start getting worried about stuff having failed!
    Good Luck!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Default Manuals
    and getting a manual online is a cheap way to find all the testing needed for your s pyder. Even if you don't do the work yourself. Remember unless your airbag leaks down, in which case you will hear the compressor working often, you may not notice it. The system is a leveling one unlike others it will not make the Ryde softer or harder or make it Ryde higher or lower than level.... one quick check is the leveling arm attached to the swingarm.
    ​2012 RS sm5
    Active Member R FUN's Avatar
    Apr 2013
    Rocanville Saskatchewan canada
    Does your horn work as the compressor is on the same fuse. Do all the other checks as advised but I would think your compessor packed it in as hundreds of others have, a common problem as mine has and my friends both on 2012 RT Limited. If it is, a cheap way and simplest is bypass the compressor and run an air line from the shrade valve to the air bag and manually adjust the pressure to your liking. Or have the air compressor replaced with an OEM compressor for $500.00 Plus just to fail again. Good Luck.
    Roger
    2012 RT Limited
    Vertika Floor boards
    Painted rear fender & dash
    Carbon fiber panels
    Utopia back rest
    Baker air wings
    Elka shocks and relocaters
    CB radio
    ISO hand grips
    Tric LED fender light
    Turn signal lights in mirrors
    RT-S PE#0801 timeless's Avatar
    May 2010
    Punta Gorda, Florida
    Default There are
    some good after market units that are rather inexpensive compared to the OEM unit. however, that means that you or a friend do the the R & R. There are some instructional videos on this subject also, Doc Riverside has a very good one.
    Quote Originally Posted by R FUN View Post
    Roger
    Dec 2013
    VIAIR do a little compressor that is continuous rated & has better air flow than the OE unit & altho round in cross section rather than a flattened oval, will fit in the same spot once you clock the pump head & valve around so it points in the right direction without hitting the wheel or suspension. Can't remember tyhe number, but I think it's 9500 or something vaguely like that....
    Nov 2016
    Then I'll start checking electric conections, the leveling arm and leaking.
    The main problem, I think, will be to achieve space to work on it and see what is happening.
    If at the end I need change the compressor I'll go for the VIAIR and I'll do the replace when
    I change the rear tyre.
    Thanks a lot everyone for your help once more again.
    I'll keep you informed!
    Active Member 007james's Avatar
    Nov 2015
    Roanoke, Virginia
    Quote Originally Posted by mcalva View Post
    My 2012 RT Limited was bottoming out every time I hit a bump, and my Dash light would not go off. Also, my horn would not blow. I suspected the Air Bag was leaking, so took it to my Dealer to check. They did all the normal leak testing, and determined my Air Bag was NOT leaking, and put it back together, and charged me $100 and sent me home. The next day, it still bottomed out, and my Dash light came on and horn wouldn’t blow. I took it back to the Dealer, and they kept it for a week, then informed me, my Air Bag WAS leaking, and my Compressor was bad. The Estimate, to repair, for Parts & Labor was $1300.00! I was NOT a Happy Camper. MY Spyder had 55,400 miles on it, at that time, and It also was ready for another set of new tires, and the Valves had never been adjusted. But I had just spent $1100.00 on it, with a Laser Allignment, Oil and filter service, plus a new Battery, and Brake Pads and fluid flush! So, another $1300 for a Spyder with that mileage was not making me happy, altho it WAS still running real good, long story short, I negociated a Deal with the Dealer, that they keep my 2012 as is, for a Trade against a new 2016 RT Limited left over sitting on their Show Room floor. ( that was in April 2017) its now Thanksgiving Day, 2017, and I have 13,000 miles on my 2016 RT Limited. ( Dealer detailed, serviced, and put new tires on my 2012, and sold it in a month for $5 Grand more than they allowed me on Trade! But, I didn’t think I would ever be able to sell my 2012 on my own, and did not want to put any more money in to it. ) I love the 2016. It is superior in lots of ways over the 2012. Gas mileage is much better, more power, lower RPMs, floor boards, fantasitic way the front fender guards keep the water off my feet and legs with the new set up. The 6 speed Trannny and different way the Clutch engages is also a Joy, and very noticeable as compared to the 2012. I had a Laser Allignment done, and front wheels spun balanced, before I took possession of my 2016, in my negociations with the Dealer, and I still have not changed out my real Kendra tire, which still has quite a bit of out side thread left, but I plan to change it soon. The front tires are still looking great, and are still in balence. I had Belt Chatter right away, and bought and intalled Doc’s Belt Dampener. The spring broke and Doc replaced it under Waurentee, and its still OK. My Dealer had a 2017 RT S on the floor when I bought my 2016, which I could have bought for the same price. But I wanted the RT Limited, because I did not want to sacrifice my Garman GPS, Radio, Sliding Wind Screen, Chrome wheels, etc. so my 2016 was the best choice for me. I ride all year, as long as tne Temp. is above 45 Degrees F. And it is not raining or snowing.
    2016 RT Limited , Black & Lava Bronze
    Nov 2016
    I continue having the problem.
    I wonder if I could eliminate the whole rear shock system (compressor, shock absorber, air tank, level lever) and replace it with a good "all in one" shock and avoid a lot of problematic items at once.
    Should modifications be made to "the nanny" to eliminate the level sensor?
    Jul 2014
    Nowhere
    Look at the air bag protector from Roadster Renovations. Doc ran into this problem a while ago and put together a kit to help prevent it happening again.
    https://www.roadsterrenovations.info/
    http://www.spyderlovers.com/forums/s...-Pump-Replaced
    "If you can't be a good example, then you'll just have to be a horrible warning." Catherine Aird
    Nov 2016
    Hi!
    I'm sorry by the delay but at the end I decided to eliminate the ACS system and install a new EMC SportShock 2.
    In this way I wanted to eliminate the small problems of the rear suspension system derived from the multitude of components involved.
    I've decided it was the best solution.
    Thanks everyone for your help.
    Jul 2010
    Las Vegas, NV
    Default Ride?
    How is the ride quality? Is it adjustable? Might be a great solution to an expensive problem!
    Joe Meyer
    Very Active Member stmike 1800's Avatar
    Mar 2018
    Ontario ,way up north
    Roger
    I like the Vertika Floor boards you have ,nice bike ,never seen one like that .
    2018 RTL , dark blue
    Nov 2016
    Quote Originally Posted by cptjam View Post
    I can't say at the moment if the ride quality is better, equal or worse than the original system at the 100% but in my case is much better cause I have now allways the same answer from the rear shock. The shock is the EMC SportShock 2 for Can Am - modèle 998 Spyder RT - Rear - year 2009 - 2012.
    I've ordered in France cause the ussines is 700 km from home (Barcelona, Spain) , near Lyon (France), but you have the EMC in Florida too.
    Yes it is adjustable.
    "The SportShock 2 BLACK is a tri-tube damper with low pressure gas volume compensator easy to adjust.With 26 clicks, it has a wide range of use to satisfy all tastes.
    One wheel adjusts comfort (high-speed movements) and the other wheel adjusts the grip and sportiness (low-speed movements).
    Unlike an emulsion damper, the SportShock2 keeps a suspension of consistent quality and a good ground connection despite a bad road network or a rise in temperature.
    The springs are chosen by EMC according to the general state of charge indicated by the customer."
    https://www.emc-suspensions.fr/64574...e-sportive.jpg
    Oct 2016
    Faribault, MN
    mcalva, When you eliminated the ACS system, did you have the air valve, compressor and air bag removed entirely or just change the stock shock out to the new shock?
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Nov 2016
    Quote Originally Posted by DGoebel View Post
    Hi.
    I went to the official service to unchek the Nanny ACS option. Now the button from dashboard doesn't go, neither the level lever nor compressor, (although the compressor no longer worked), completely deflate the suspension's balloon and assembled the new shock absorber.
    At the momment I have all the ACS system mounted as "backup" but if everything goes ok, after a time I will disassembly all the stuff
    to remove the clutter and leave the installation completely clean.
    I'm using the BRP information to mount the part number ROADSTER KIT - ACS rear suspension (In my case to dismount) ;-)
    Part number (SKU): 219 400 323
    Product: Touring car
    Project No: rsi2011-045_rev1
    Instruction Sheet P / N: 487801515
    Review number: 1
    Date of revision: April 25, 2013
    Covered item: ACS rear suspension
