Results 1 to 5 of 5
Thread: RTL Valve stems
    May 2017
    Mesa, Arid-Zone-A
    Default RTL Valve stems
    I have a difficult time airing up the rear tire of my 2014 RTL. My fat, pudgy fingers just don't slip into the slots to get the air hose on/attached. I have Lamonts portable air pump and it works great. Just having a tough time attaching it. I am about to have the rear tire changed and wonder if any of you have successfully installed a different air valve stem that solves this problem. My Gold Wing has a fixed metal ninety degree stem that works great for that application. Anything like that for the Spyder?
    Semper Fi
    Jul 2014
    Mint Hill, NC
    Although my arthritic thumbs make it a little more difficult I'm still using the OEM valve stem but the sites below come from previous discussions of your problem.
    https://www.jpcycles.com/search/search?Ntt=valve+stems&N=28012733&Ntk=All
    http://www.motorcycleanchor.com/tire_valves/
    https://www.kurveygirl.com/shop/adva...3p99ktr2h03l90
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Feb 2012
    Spring City,Utah
    go to your local Harley dearly and get the valve stem extension made for the Ulta Classic. They have the same problem. It is about $10 bucks.
    https://www.shoputahharley.com/produ...SABEgLGMPD_BwE
    this is what it looks like
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    Default Replace with metal valve stems
    If you are taking the tire off anyway, replace the valve stem with either straight or an "L" shaped metal valve stem; whichever works best for your fingers and attaching an air chuck. As noted from others, readily available.
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Very Active Member SteveLaoyster's Avatar
    Nov 2015
    Myerstown, Pennsylvania
    You can also put a angled extension on the existing valve stem.
    AKA Jud Smales, Four Year Spyder Ryder!
    "Quando Omni Flunkus, Moritati"
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Driver & Passenger Gel Pads in Seat
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Break Stripe Kit from Wrap My Spyder
    2016 RT-S , stock not yet Pearl White
