BajaRon's Bargain Basement
From time to time I get closeouts, brand new stuff without the retail packaging, returned items that are still new, and slightly damaged goods that may be cosmetically compromised, but still as good as a new product.
I am going to start listing them here. So drop in and visit once-in-awhile and see if you can pick up a deal! :thumbup:
If you need additional information on any item please email me at fyredad@hotmail.com or PM me here at Spyderlovers. I usually get to my email more quickly than a PM.
Krikit II Belt Tension Gauge
$18.00 delivered to 48 US States. I will ship Worldwide. PM or email me at fyredad@hotmail.com
Accurately measures drive belt tension on all flat belts including the Spyder.
This Gates tension gauge measures from 100 to 320 lbs or 50 to 150 kg. There are other Krikit gauges with different tension ranges. This is the correct tension range for your Spyder drive belt.
https://encrypted-tbn3.gstatic.com/i...5zDkNXVFqqeRaQ
I did not intend to stock these gauges. Buying these 1 at a time can be expensive. I had a customer who wanted one so I purchased several to get the price down. I posted the remaining gauges here on Spyderlovers and I thought that wold be it. But I sold those gauges pretty quickly and there are more who are interested in getting one so I've ordered more. They will be here early next week.
Here is a great informational video on the correct use and accuracy of this little gauge. They make it sound harder than it is. It's actually quite simple to get a good, accurate reading as long as you are a bit careful to do it right. You can always check yourself by taking 3 or 4 readings. If you are doing it right, you'll get the same reading every time. The gauge is easy to read and you can carry it with you. I find myself using my gauge more on other Spyders than on my own as people are always curious about having a properly tensioned belt.
If your belt is too tight you can destroy a set of rear wheel bearings in pretty short order. In some cases too tight belts have destroyed the front pulley and output shaft. If it is too loose you can get unnecessary vibration and wear.
This video is of the Dayco branded gauge. But all these gauges are from the same source and simply branded for the various companies. They are all the same regardless of the branding.
For some reason this video does not instruct you to 'Zero' the gauge each time before using it. And they wiggle a bit with the finger when depressing the gauge. You should try not to wiggle, but it isn't critical either. There are written instructions that come with the gauge and these things are mentioned there.
https://www.youtube.com/watch?v=z11wfc-0-hY
Firstgear Heated Pants - Medium/Large - New!
I have a pair of brand new, with tags, Firstgear heated pants in stock. I carry the full line of Firstgear products including the heated gear so if you need more than just the pants I can take care of that as well.
Normally I have these drop shipped directly from the warehouse to you. But I ordered these in for a local customer who changed his mind.
These retail for $189.95. My price (Delivered to the 48 US States) is $159.00. I will ship these worldwide. If you are International please contact me for a shipping quote.
You can see reviews of this Firstgear Heated Pant Liner by clicking on this link. If you have any questions please email or PM me here on Spyderlovers.com
https://www.revzilla.com/motorcycle/firstgear-heated-pant-liner
The Firstgear Heated Pants Liner is form fitting, with a close fit for optimum heat transfer to body. Made of Spandex fabric allowing full range of movement for any activity and fits easily under your outer garments. The Heated Pant Liner is designed to keep you warm when plugged into a DC power source.
Features:
- Packs into its included zippered pouch
- Heated zones cover thigh and knee
- Integrated sock plugs stow in their own zippered pockets when not in use
- Coaxial plugs
- Performance fabric: Anti-bacterial treatment prevents odors and Moisture Management wicks moisture away from skin
- About 35 watts, 2.7 amps at 12.8 volts
- 1-year limited warranty on liners–lifetime warranty on wiring
https://www.revzilla.com/product_ima...liner_zoom.jpg
