Oil research - read only if interested😀
I've Cant beleive the only oil for a Spyder is some special blend only available from selected outlets. I started searching and started with my owners manual and the API website (www.api.org). The oil recommended by BRP for my 2010 is API service SL, SJ, SH and SG and do not use API SM or ILSAC G4. The API website says:
SL is for 2004 and older automobiles
SJ is for 2001 and older automobiles
SH is now obsolete
SG is now obsolete
The main problem is with/or without friction modifiers that can raise heck with the wet clutch system in a Spyder. I started searching motorcycle oils and found the mellowing and others:
Mobil 1 motorcycle oil $9 a quart at WalMart
"Mobil 1 Motorcycle Oils are full synthetic, high-performance engine oils formulated specifically to meet the demanding needs of motorcycle engines. Mobil 1 Racing 4T 10W-40 is designed primarily for on-road, high-performance, 4-cycle sport bikes, however, it may be used in other types of on and off-road 4-cycle motorcycles especially where a 10W-40 viscosity grade is specified. Mobil 1 V-Twin 20W-50 is formulated to help offer outstanding protection in 4-cycle, V-Twin type engines, particularly those which are air cooled and tend to run hotter than other types of engines.
Mobil 1 Racing 4T 10W-40 and Mobil 1 V-Twin 20W-50 are recommended for 4-cycle, motorcycles which specify the use of a 10W-40 or a 20W-50 engine oil, respectively. These products will help provide excellent performance in motorcycle engines that are designed with a common engine/transmission lubrication system or where the engine lubrication system is separate from the transmission system. In the case of the latter, follow the manufacturer's recommendation for the type of fluid to be used in the transmission. Mobil 1 Racing 4T 10W-40 and Mobil 1 V-Twin 20W-50 engine oils are designed to help provide the proper frictional characteristics necessary for wet-clutch common engine/transmission systems."
The price is the same if you buy a gallon jug at the dealer so that is not a big deal, I'm just thinking of an alternative if you get stuck in BFE. Is this a usable alternate in a pinch? Those with newer bikes, what are the oil recommendations?
And the beatings will continue....
:bdh::bdh::bdh::bdh::bdh::banghead::banghead::bang head::banghead: Will it ever end??? Doubt it.
Just having fun!!! Hope everyone has a good weekend. Doesn't look like any riding is going to happen around here on Sunday.
