zumo 660 tri axis moumt
garb55
I purchased the tri axis handle bars and found the Zumo mount is not transferable
BRP wants $180.00 for the mount that fits the tri axis handle bars
This was my way around it
1 I cut the original mount to fit the slot at the top of the new handle bar
I have the Touratech locking mount for my Zumo so I did not want to bolt it from the top that would alow someone to remove the entire assembly with one bolt. The handle bars come drilled and tapped for a 6mm bolt to mount the new BRP mount
I drilled the hole out to fit a 1/4 20 bolt 3 inches long
Then i drilled and tapped the mount I cut for the 1/4 20 bolt
I installed the bolt from the underside of the handle bars and cut it flush with the GPS mount
Then I filled the space with Black silicon
Last I painted the mount with plasti dip
Since the mount swivels up and down all adjustment bolts on the handle bars are easy to get to
Just saved myself $180 which is what the locking mount cost
In order to remove the mount I would have to take the handle bars off so I feel it is secure
Don
