lawrenc454
RT-S PE#0803
Installed and there are a couple of things I have done differently. One it comes with bolts and brackets for a bar mount which I took off. I added a second set of rubber bushings between the two plates so that I didn't lock it down too tightly. The Zumo mount fits perfectly and the four holes through it and the Touratech mount are perfectly aligned but if you tighten the four screws too much you might misalign the the upper and lower plates (experience from a previous mount on another bike - isn't leanring great). Will modify my Sun Shade tonight to work with the mount.
Lonnie
Lonnie
