Zumo 660 Lock
I have one installed on my RT and tweaked it a bit by using longer spacers and screws fro the local hardware store. I would not recommend leaving your GPS unattended without one!
Locking mount
I have the Spyder RT -S SES 2010 Model
The zumo 600 is fitted to the Handlebars using the same mount as supplied with the Spyder RT - Limited (BRP Mount)
I fitted the touratech locking mount to secure the ZUMO as it was easy to remove it without the locking mount - meaning removal each
time when filling up with fuel etc
You just need to add a plate - I used Stainless Steel behind the original mount just to bring the holder out a fraction to allow access to
the lock with the key as its close to the handlebars
I have also made a sun shade for the Zumo see Thread #23
http://www.spyderlovers.com/forums/showthread.php?17418-Shade-Rain-Hood-for-Zumo-660&highlight=shade
Here are some pictures which will show the Touratech locking mount as fitted by me
Eddie Sheppard
Reading UK
Spyder – RT-S SES (AUTO 2010 Model)
List of Mods :-
Added Zuno 660 -Garmin kit as supplied on the Spyder RT Limited
Digital Voltmeter and Digital Clock to replace Fuel and Temp gauge – Fuel and Temp now
displayed in Cluster Display
LED Bulbs Reversing Lights,Front position lights
HMT - Brake Light
LED – Running lights
LED - Mud Flap lights
Rear extended Mud Flap
LED Light in Rear Trunk
Sport Tall Wide Clear Windshield
Chrome 2011 Front Lower Wind deflecors
Utopia Backrest
S/S Seat Prop
S/S Handlebar Weights
S/S Grills both sides matching
Bottom Panel S/S Protection
S/S stronger Funk Lid brackets
S/S Bracket for RBNS Hood for Zumo 660 GPS + TourTech Lockable Mount
Rubber Tank protector on glove box
Grip Puppies
Power Socket in Switch Cluster and at Rear passenger Handrail
Rear Speaker Switch for passenger On/OFF
Upgraded Front Marine Speakers
Bluetooth On board Radio to Sena SMH10 Headsets
I agree, but I think you have to use this one because you need the lock on the top to get the key in and out. Yes, you do have to use spacers as well. Sorry I forgot the link.
A simple trick is to use a zip tie where you push the tab to take the Garmin off. Use a wide one so that the tab can't be pushed in to take the Garmin off. Now you try and take it off. It would certainly slow someone down trying to take it off. I figure it keeps honest people honest and if someone wants it bad enough they will get it lock or no lock. I have had mine on the bike for 20k left uncovered for most of the times in all types of parking lots with 0 issues. In fact my Garmin has never been of my RTS.
Hmmm, I am missing something. When I remove my key to lock my trunk, I remove my Garmin and put in the trunk with my gloves, etc and lock it. So easy to remove on the RT-S.
:spyder2:
