SpyderMouse22
I was reading many posts on here about differant things. I am surprised how much information has alot of truth to it. Any post that differs from the owners manuel i do not put thought into. For example i read one about puting 20 lbs of preasure into the front tires. However i was reading about running the Spyder at higer RPMs I wont go into the number because that is a whole new can of worms. I went out today and ran at higher RPM . WOW i have to learn to ride the Spyder all over again. I think i have 2nd 3rd and 4th gear figured out however i came to realize that because of spped limits and situations you cant always run where you want to. My question is about 1st gear. I live in a town with a speed limit of 25mph. So do you think it is ok to run in first gear for the most part? It is not easy getting used to running in higher RPM and it will take time to do this.
