Don't forget that
IF your Ride Height Sensor is connected to the swing arm (look at lower Left Hand Side of the bike, under its skirts, on top of the swing arm, just below the top chord of the belt...
 ) and working properly (often either/both are questionable, especially if no-one's touched it since the dealer's techs last did!
 ) then that Up/Down Hard/Soft switch thingy on the dash is really just a gimmick - the static ride height should be set in the computer and pretty much nothing you do to the switch &/or the air bag pressure will change your ride height for very long, it'll only work/vary anything to
KEEP your static ride height at the preset level as the load on the bike varies, and it won't really have
too much impact on the Hard/Soft of your ride either - the ACS is designed to and if working, will simply
MAINTAIN YOUR SPYDER'S PRESET RIDE HEIGHT! :lecturef_smilie:
Your required pressure to maintain that preset ride height may well vary significantly from anyone/everyone else's, even tho your preset ride height shouldn't be too far off theirs,
IF it was ever set properly; so the fact that yours happens to reach 20 psi (or 90 psi
 ) is pretty much a moot point &/or irrelevant.... It could well be that 20 psi is all your air bag needs to maintain the preset ride height of your Spyder given the load you impose, and even if you do adjust it manually via the Schraeder Valve under the seat, if the system is working
at all like it
should, the very moment you start to ride again it'll immediately return the air bag pressure to 20 psi or thereabouts, only ever changing
IF the load on your Spyder changes. And if the ACS
ISN'T working as intended, all bets are off and that might never change even if the load does... or maybe not!
Bert's laid out your options very well - trying to achieve anything else with the OEM ACS set-up is pretty much a recipe for much grief and frustration, and it'll probably do a very good job of removing $$ from your wallet &/or bank account too! :gaah:
The ACS is a prime example of one of the
GREAT Concepts that BRP's come up with for our Spyders, and an even better example of the poor execution of said concept!! :yikes: :banghead:
