Windshield Grommets cracked after only 6 weeks?
SpyderSue
I purchased my F3 about 6 weeks ago, and the windshield grommets are already cracked and dry. Has anyone else had this problem? Small thing, but annoying nonetheless. :banghead:
CRACKS
If your dealer REFUSES to re-place under warranty and you don't want to bother filing a case with BRP :banghead: ......I fixed an original F-4 ( not the same co. as now ) that had the same issues. I had some thin sheet metal that I cut into small squares and drilled holes the same size as the bolts.....I then glued these on both sides of the windshield using SLOW CURE ..JB Weld...Get some bolts and nuts that will fit the holes ..... smear a little Vaseline on them, so the JB weld won't stick ....use these to hold the metal patches on for 24 hrs. until the glue is FULLY CURED....The bolts should slip out easily and you can paint to suit after washing off the Vaseline...................good luck ......:gaah::gaah:.........Mea Culpa, I just realized you said ....GROMMETS ....so this fix doesn't apply .......but it's good info anyway ....and it took awhile to type ( at least with two fingers :roflblack:)......so I'm leaving it ...:dontknow:............Mike :thumbup:
