Replace the retainer sleeve and hex bolts on the upper right (sitting on trike) windshield adjuster arm this afternoon. Easy.
Required:
One short sleeve and 2 hex bolts from this repair kit, which has 1 long (center bottom arm attached to the windshield motor), 2 short arms (for the uppers on each side), and 6 hex bolts with locktite on the tips. Part # 219800355
2 Allen wrenches (I used 1 standard and 1 metric of about the same size. The metric fits a bit tighter).
Steps:
1. Remove the broken sleeve/bolt assembly (you might need to push it out from the broken side).
2. Screw 1 hex bolt into 1 end of short brass sleeve until it is snug using an Allen wrench and channel locks.
3. Insert into hole through windshield mounting bracket and adjustable arm base with the bolt toward the outside edge.
4. Carefully thread the other bolt on the inside edge to get it started.
5. While holding 1 Allen wrench in the outside hex bolt, tighten the inside hex bolt with the second Allen wrench. There isn't room to rotate the wrench 360 degrees and certainly no room for a driver. So you'll have to do it the slow way.
6. Tighten until neither Allen wrench moves under firm pressure.
Finished! Oh...now clean the smudges from your knuckles off the inside of the windshield.
P.S. The bolts I removed from my 2012 RTS had star heads in them, but the replacement kit has normal hexagonal head (regular old Allen wrench) bolts.
