Will RS wheels fit newer RT's?
Will these wheels fit on '20-up RT's? Say's they are for RS models only. I don't care for the solid black wheels on mine.
https://leadersrpmshop.com/can-am-s...MIyvv3h7S9_gIVTebjBx2g6AXQEAQYCSABEgJPCPD_BwE
I stand corrected. I knew what Peter said but had forgotten it. The pre-2013's will not clear the calipers on the 2013+ models. But you can go the other way. Any of the 2013+ wheels will work just fine on the 2008-2012 Spyders.
Thank you Peter for keeping me between the guardrails!
Since it says they "Fit - 2012 & prior RS & RS -S models", it's most likely they are pre-2013 RS Rims - ALL pre 2013 OEM front Rims were 14" dia and while the stud pattern etc is the same, they won't safely go over the 2013 & on Brembo brakes; so NO, those Rims won't fit on a 2020+ RT! :lecturef_smilie:
You'll need to find rims that will fit a 2013 or later model Spyder, any Spyder - they will be 15" Rims, and the 15" OEM Front Rims will fit ALL 2013+ Spyders! :thumbup:
Ron & Peter: thanks, thats what I needed to know and points me in the right direction for shopping new wheels.
