Will rear shock from RT fit RS?
From what I have heard it will. Many of the rs riders I know are doing just that because the rt shocks are better than what is on the RS. If you don't get another confirmation from others pm Len the pit bull buggy and he knows for sure
The RT rear shock will work on an RS but you do not want it. I have an RT with an RS-S rear shock because the RT shocks are so weak and always go out. The RT uses air bag assist and therefore do not have as heavy duty rear shock. My personal openion is this is why so may RT rear shocks go bad. If the air bag leaks down or is ran with no air pressure then the rear shock can no longer handle the load and they bottom out every time you hit a bump and this blows the seal, especially if riding two up. If you have an RS you already have the better rear shock, unlike the fronts. There are to setups for the RS though. The RS-S has a single stiffer rear spring and the regular RS has a two stage spring. I love the RS-S rear shock on my RT! I just run less air to get the same ride as before. Also the RS ans RS-S have adjustment cams like the front shocks and the RT shocks do not.
