Will F3 Limited Floorboards fit on an F3T?
shannonmarie
Hi all.
I got a stock 2023 F3T a few months ago and want to put floorboards on it. I’m extremely disappointed in Can-Am for not making floorboards for their Touring model. Long hours over multiple days and no floorboards?!
I was wondering if anyone had tried putting the driver floorboards from a Limited on a Touring model. They look like they have the same frame. The way the pegs and floorboards mount look the same as well.
I have seen the SlingMods and other brand aftermarket floorboards but I prefer a more stock style plus rubber padding on the floorboard to help cushion my feet.
Thanks!
Shannon
I prefer/need the shorter boards. I like to be able to put my feet on the ground and stand up at stops. But more importantly, I need to be able to put my feet right next to the bike when mounting/dismounting because of my arthritis. My legs don’t work so well, and balancing on the floorboard would be dangerous. A few times when having a bad leg day, I basically pulled myself off the bike far enough to fall into my wheelchair.
They work. I actually got mine from a guy who had a Limited and preferred the pegs. But they are a direct fit.
Quick follow up: Did you just swap the peg/floorboard part itself or did you swap the entire assembly, mounting bracket and all?
For me, I swapped the entire thing. But the rear bracket is the same on both. I know this because the metal is sort of cheap pot metal and one of mine broke. We were able to use the rear area from a peg and use it with the floorboard piece.
Awesome. Again, thank you!
I’ll post a follow up with the part numbers in case anyone else wants to do this.
I had this exact question. The dealer said that there wasn’t a “kit” solution so it would have to be pieced together, about $650 ��.
Same problem with my 2023 F3T purchased in Aug 2023. I bought the parts from the dealer and put OEM gear on it. I had to wait for several months for the rubber pads so I removed the boards from my 2016 F3T and rode with them on the 2023 for the rest of the season. It was a direct swap.
My 2023 had pegs and some of the components could be used with the boards. If Limited boards you are looking at are about 11.5" X 5.5" they should work. The brake pedal is part of the right pad assembly. I don't have a convenient way to send pictures but if you haven't worked this out yet I will try to post a photo.
