Will a 2020 RTL Passenger Backrest fit on a 2020 F3L?
rblower
My wife likes the way the passenger backrest on the 2020 RTL wraps around vs the one on our 2020 F3L. Does anyone know if these are interchangeable? I've compared pics on Ebay and it looks as if they both have two tabs and two screws holding it on.
Considering adding an F3 to the stable. I was wondering if the 2020 RT Ltd backrest will fit on a 2024 F3?
I'm pretty sure that the answer to the RT/F3 compatibility question, for either the rider or the pillion backrests, is No! :rolleyes:
But now that I've posted an answer, I'm very sure that if it's not the case, someone will pretty quickly chime in and say so! :thumbup: :roflblack:
UPDATE- I wasn't specific enough and someone added the word passenger backrest. What I meant is will my slide in RIDER backrest slide into an F3 with the proper bracket?
Like I posted earlier, I'm pretty sure that it's exactly the same answer to the RT/F3 compatibility question, for either the rider or the pillion backrests which is NO! :lecturef_smilie:
Mind you, anything is do-able, if you want to throw enough money at it :rolleyes: but I'm pretty sure that the seat pans & the brackets underneath them aren't the same across the RT & F3 models & as a result they aren't readily inter-changeable, not without doing a bunch of mods/fabricating... :banghead:
