will a 2009rs front end fit a
Hard to say..!!
how much of the front end..?? The sway bars are different, shocks are same length but different pressures (stiffer)the other parts may be the same. Check in the parts catalog see if they have the same part numbers...maybe some one knows...good luck...:thumbup:
Yes... But why?
The shorter A-arms, and wheels with a different offset are only the beginning...
You'd need for starters:
A-Arms
Shocks
Brake lines
Anti-Swaybar
Wheels
And you will then need to space the fenders over a bit to line up with the wheels (Unless you leave the RT wheels in place)
But; it is all possible! :thumbup:
well thanks for the advice, we are thinking of buying a couple of wrecked spyders to build a good one is why I asked.
You had us wondering. Building a good one from a couple wrecks sounds like it would be an interesting winter project. As finicky as the :ani29: can be, don't know if I would recommend it. If you do decide to do it, please keep us posted. Would be interesting to see how it all works out. :thumbup:
