Wild hog
wild hog
What is the belt tension for a 08 can am 990? Anybody know the torque setting for the front sprocket bolt.? Last, how is the 660 loctite applied to the gear & or bolt. Thanks guys &gals
Little checking.....
According to the manual....
front sprocket bolt is 81 ft lbs 2008-2009 later models 92 ft lbs
Tension 450N +/- 150N ( we use the krickit and run 160 to 200 lbs, I keep it on the low side)
Thread lock on the bolt threads only
If you remove the front sprocket bolt it is recommended you install a new bolt (if ordered from BRP or Cheapcycleparts.com it will come with the thread lock already applied. :thumbup:
I kept my 08 GS on the loose side about 165lbs ….measured ON THE GROUND …. I never had any issues and I didn't feel any vibes ….. Mike
