Wide Vu Mirrors Upgrade
barbarosa
Mounted Wide Vu Mirrors today.
Took a ride, wow, big improvement .
Can see to the rear much better than with the stock mirrors.
Easy upgrade.
I just bought a set for my 2020 RT and at first they were great but they keep coming loose. The edge isn't deep enough to completely cover the stock mirror and is a super tight fit and keep popping loose. Do they not test their product before they sell them?
I had these on my 2014RT and was super pleased with them, so I bought a set for my 2020RT. Again, super pleased with the results. No negative issues for me, only positive so far. Honestly, these are the mirror lens that should come from the factory.
I have them and like them a lot .... but one of my mirrors did start to vibrate and come loose after a couple seasons. So I pealed the mirror off and put a new piece of 3M a double sided foam tape back on the mirror and stuck it back on the bike. Good as new, at least for now.
P.W
I would contact TricLED and fully explain your problem. They are excellent at responding to customers and providing resolutions to their problems.
Ok so last night i carefully removed them and sanded the inside edge all around. Looks like there was a build up of glue that makes it a tight fit over the stock mirror. Cleaned up real good and restick back on. They fit way better now. I still think the width of the mirror edge needs to be wider to fully cover the stock mirror.
Do the stick on's change the rear view objects from appearing much further back than they really are, similar to OEM's?
