Why can't I ask a question regarding my cruise control, like everyone else asking questions?
StevenQ
Why does this have to be a message, when everyone else seems to be able to ask questions. I really don't understand what is going on.
What makes you think it has to be a message?? :unsure: Have you tried clicking on the orange 'Post thread' button that's on the top right of the page opposite the Section/sub-forum? :oops:
That said, it appears that you've been quite successful in starting a new thread in the past, earlier this year even; and then you've successfully started a new thread with your post above, and that's really all you need to do; altho we do ask that you always try Searching FIRST, and if there's not a fairly recent thread asking/discussing the same or a closely related topic for you to Post a reply in (see the blue 'Post reply' button down toward the bottom right of each page/after the last post in the thread) only then should you consider starting a new thread. But if you do, and you want helpful answers/meaningful contributions, then you should first find and go to the most appropriate Forum section & sub-forum for your question/new thread (like Forum Support and Testing for this question/thread, rather than Spyder General Discussion, because this particular thread is really about how to use the Forum rather than anything to do with a Spyder ;)) and only then select the 'Post thread' button. Once you have the most appropriate sub-forum open and you've selected 'Post thread', you should always briefly ask your question in any new thread title, as you have done above; or at the very least, tell us what you expect from the thread in the title - doing either will help members/readers to have some idea of what you're on about/want to achieve, and that will help you get answers now, and also help any/all readers as well as anybody/everybody searching for the same or similar info in the future. (y)
So for now, I can only suggest that I really don't understand what is going on here/what your problem is - could I have more info/a bit of background/context please?? ;)
Ps: If you do want to ask any questions about your Spyder, or even provide replies, then it really helps all readers if you make sure to include your Spyder's year and model info in the detail provided; and if you don't want to type that info every post you ever make, then as requested in this thread/Sticky:
it will really help all readers if you add that info in your Signature block so that it will appear in every post you make (see mine below! ;)) The link above should take you to page #7 of the Sticky, and post #129 by @racoon provides details on how to add that info on this platform rather than the old platform. Over to you. (y)
