Joel The Biker
After having issues with my Elka shocks(leaking oil and noisey clunking internal valving), I am searching for opinions about which is the best orientation to mount aftermarket shocks. I mounted my Elkas with the spring on the top. Now I am thinking it is better to mount them with the spring on the bottom. Here is my reasoning. With the spring mounted on top, the nitrogen gas will be accumulating near the piston seal, which could dry out while sitting and some nitrogen could leak out. With the shock mounted with the spring on the bottom. The oil will settle near the piston seal and have a lesser chance of leaking. Maybe I am overthinking this. I ordered new shocks and want to prevent the same issues I had with my Elkas.
