Which way should I Adjust the Rear Suspension back down for solo ryding?
hihosilver28
I have a Ryker 900. I know how to adjust the rear suspension for a passenger, but want to know how do I adjust back when I'm riding alone.
Do I keep going in the same direction from 5 to 1 or do I have to go in reverse - 5 - 4 - 3 - 2 - 1 to get it back to it's original setting.
Thanks for the advice.
The 900 & 600 use a ratcheting cam adjuster with stops at each end (upper and lower limit). To reduce pre-load, (as Tslepebull states) you turn the adjuster in the opposite direction 1 notch at a time.
