Which fuse on 2012 Spyder Rt Limited for rear 12v outlet?
Jar122000
Hello,
I have a 2012 Spyder RT Limited and the 12v outlet in the rear trunk does not work. I want to check the fuse to see if its blown, but I cannot find anywhere in the manual which fuse goes to this 12v outlet. Can someone tell me which fuse and what else used this same fuse so I can see if anything else on that fuse works. It seems as if everything else works. Thanks,
You have two fuse boxes, the rear box under the seat and the front box in the frunk on the right side. Front fuse box fuse #9 runs just the 12v outlet. should be a 10A fuse.
