Which compartment gets stuck closed?
Which OEM compartment gets stuck on your Spyder?
  • Total voters
    32
Just curious to see if there are compartments more prone to this than others
I just fixed my left side pannier .... After finding the adjustment cable ( it needed quite a bit of tightening ) I adjusted it as per the video and now it works great. ..... Early on after I bought my RT I did have frunk issues, so I made a pull cable and that fixed the issue ..... Mike :thumbup:
Should have know you'd have the answer to my predicament :) Thanks
Glad I could help ..... which " predicament are you referring to ?????? .... During " Fjrwillie " visit I added a pull cable to His RT ..... the rear pannier cable adjustment was a lot more complicated ..... Mike :thumbup:
No trouble with mine in 5+ years of ownership . I added pull cables on both the frunk and seat ( just in case). Lubed all latches at yearly oil change. Wish the cooling system was as reliable.
Lew L
My Left Rear Pannier got stuck shut while on my last trip (luckily it only had my "Covid Kit", pillow and jump starter) and I wasn't sure what to do about it. It has always been the left rear for my Spyder.
