Where is the engine serial number stamped?
RodO
Just back from trying to have my Spyder registered. Because it's used, I need to show them the VIN and the engine serial number on the bike. The VIN is easy, but does anyone know where the heck is the engine's number stamped?
:gaah:
Thanks,
Rod.
The two places the vin number are located are on the swing arm and under the lower front right A-arm. The EIN engine Identification number is near the left Rear Engine Mount, under the exhaust mount. I don't know if you can see it with out unbuttoning the left side or not. My dmv did not need to see the EIN only both VIN's:cheers:
Found it -- thanks. And, yes, all 3 panels have to come off from the left side. You'll need a light and a mirror to see behind the exhaust pipe and partially covered by the frame. If it's really dirty the numbers might be harder to see as they're only lightly stamped.
Rod.
