Where is the constant 12V accessory leads?
lightman02
I found the switched leads for the 12V accessory, but where are the unswitched ones? Are there wires from the fuse box or just empty terminals in the fuse box that need to be wired???
Thanks
They are bundled with the main wiring harness in the center, near the steering as I recall. There is a small violet/orange wire and a black ground wire. You can probably follow them from the fusebox with the tupperware off.
-Scotty
Not to hijack the thread, but the 12V harness designed for use with the cigarette lighter plug connector installed in the rear left of trunk... is it switched or unswitched?
Its generally hooked up to the switched accessory.
Thanks I found the connector on the top by the headlights, it is a small useless connector which i will cut off and replace with a weatherpack connector.
