whats proper way of jacking front?
decibel
i need to jack up the front of my spyder
i need to remove the front wheel
what is the proper location to lift it?
thanks
When I would do my oil changes, though I had a sloped driveway, I used an ATV jack rated for 1500 lbs under the frunk. It allowed for stability and got the front end up and level.
Guess...!!
it will depend on the jack you will be using. Atv and motorcycle jacks can lift the whole spyder. I use a floor jack but stability is not that good so I lower onto A stands placed closest to the wheel. If you are using a sissor jack again closest to the wheel. Loosen the lug bolts before you raise the bike and torque them on the ground.. Good luck :thumbup:
